doldonics Posted October 4, 2016 Report Share Posted October 4, 2016 Hey Guys, thanks for all your help. I was planning on doing the swap later on, but I had to move the car from the house where it is parked. Some notes: - I ended up purchasing the front eye lift tool (303-1245). Could not have done it without it. - The removal instructions were pretty good, although in hindsight everything was pretty straightforward. - You can't use the trans-dapt (engine sling) using the rear eye hook behind the intake manifold. When you raise up the engine, there is not enough clearance under the cowling. So i used the metal bracket next to the passenger side motor mount. However, this lets the engine rock backwards. I removed the shift cable bracket from the transmission, and used a nylon strap on the eye hook on the transmission (attached to the hook on the engine lift) to pull the back of the tranny up. - I could not get one of the oil cooler lines off the side of the tranny, even with the special tool. So i just unscrewed the 24 mm fitting, it has an O-ring, not sure why this is not done in the first place. - I was able to get a dolly under the engine which let me slide it out the passenger side. - The front of the car had to be lifted up quite high. Instead of using the jack stands on the highest position, I used wood boards underneath for stability. - You have to strap the front of the subframe up to the front eye-lift tool when you drop the engine down. The rear is attached with the motor mount, the front is not attached at all. - Once the subframe/engine assembly was on the ground, taking out the CV joints made it easier to move the engine and tranny off the subframe. - I marked the steering wheel coupling to the rack before I removed it, that was a good move because the rack moved when I was messing around with removing the CV joints. - Took about 20 hours, I had to swap accessories off old engine to newer one. - The torque converter bolts are grade 10.9, so they are not stretch bolts. I just used more blue loctite on them. Pictures attached. Thanks, George 4 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 4, 2016 Report Share Posted October 4, 2016 Congrats! Thanks for the insights, they are sure to help others in the future Long may this engine live! 1 Quote Link to comment Share on other sites More sharing options...
doldonics Posted October 5, 2016 Author Report Share Posted October 5, 2016 Heck, this is going to be for my daughter. I have to detune the puppy so it is not so fast 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 7, 2016 Report Share Posted October 7, 2016 Great job!!! Quote Link to comment Share on other sites More sharing options...
hill392 Posted January 14, 2017 Report Share Posted January 14, 2017 Getting ready to do this now. There's not a lot of information out there. So the motor has to be dropped out the bottom? I'm getting conflicting reports on taking it out from the top vs dropping it out the bottom. Did you use a manual? 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 14, 2017 Report Share Posted January 14, 2017 It can be accomplished both ways. More of a preference as to which will work better for your situation. Dropping the frame requires more lift height of the vehicle where coming from the top the Edge would be on the ground. Your preference and setup etc. will be the determining factor. Quote Link to comment Share on other sites More sharing options...
Munday07 Posted May 22, 2019 Report Share Posted May 22, 2019 What nuts bolts and o-rings did you have to replace, if any? Quote Link to comment Share on other sites More sharing options...
erikrichard Posted May 24, 2019 Report Share Posted May 24, 2019 (edited) What an f'ing nightmare. My Edge wp is good, but if it ever shts the bed and destroys the engine I'll just call the junkyard, get it towed and not replace it with a vehicle that uses this timing chain driven wp 3.5l engine. Hopefully it won't come to that. Edited May 24, 2019 by erikrichard Quote Link to comment Share on other sites More sharing options...
Lora motor swap Posted March 12, 2024 Report Share Posted March 12, 2024 So it sounds interesting. So can l swap out a 3.5l v6 motor of out 2011 ford edge for a 2009 ford 3.5 v6 ecoboost to put back in my 2011 ford edge? Quote Link to comment Share on other sites More sharing options...
