txphilip Posted September 30, 2016 Report Share Posted September 30, 2016 I am looking for a 2010 Ford Edge fuel line. I have look at all the part house around me, Ebay and junk yards. Ford does no carry the part or connectors. Any one have a idea where I could find on at? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 30, 2016 Report Share Posted September 30, 2016 Which fuel line are you looking for? Do you have AWD or FWD? Possible to post pics? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 30, 2016 Report Share Posted September 30, 2016 Recall https://www.google.com/amp/www.autoblog.com/amp/2014/01/16/ford-recall-28k-edge-crossovers-over-fuel-line-leak/ Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 30, 2016 Report Share Posted September 30, 2016 RECALL Subject : Fuel Leak from Cracking In The Fuel Pulse DamperReport Receipt Date: JAN 06, 2014NHTSA Campaign Number: 14V002000Component(s): FUEL SYSTEM, GASOLINEPotential Number of Units Affected: 27,933Manufacturer: Ford Motor CompanySUMMARY:Ford Motor Company (Ford) is recalling certain model year 2012-2013 Edge vehicles manufactured from September 2, 2010, through April 25, 2013, and equipped with 2.0L engines. The fuel line pulse damper metal housing may crack as a result of an improper manufacturing process. A cracked fuel line pulse damper housing may result in a combination of fuel odor, weepage, or a continuous leak while the fuel system is pressurized.CONSEQUENCE:A fuel leak in the presence of an ignition source may result in a fire.REMEDY:Ford will notify owners, and dealers will replace the fuel line with one that does not have a damper, free of charge. The safety recall is scheduled to begin on February 28, 2014. Owners may contact Ford at 1-866-436-7332. Ford's number for this recall is 13S13. IMPORTANT: This recall supersedes recall 12V-438. All vehicles that have been remedied under the previous recall need to have the current remedy applied.NOTES:Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov Quote Link to comment Share on other sites More sharing options...
txphilip Posted September 30, 2016 Author Report Share Posted September 30, 2016 It is FWD. It is the rubber line that connects between the injector line and the hard lines that run from the gas tank. Quote Link to comment Share on other sites More sharing options...
txphilip Posted October 2, 2016 Author Report Share Posted October 2, 2016 I traced the lines. It is the hard line that comes from the gas tank to something by the evap can then out in a metal. I need to get the poly line that is connected from ther to the injector hard line. Quote Link to comment Share on other sites More sharing options...
