Transmission goes into limp mode
Bob Brown
Every now and then the transmission will kick out of "o/d off" and cancel cruise control, and the transmission repair light will turn on, so I put it in park, turn it off then back on. I hear a clunk when the motor turns over then it's usually find, may need to repeat the off and on step a few times but it acts normally after that, can't find any mechanic or other online source describing my issue. Thanks
How many miles on your Edge? The most frequent issue with the transmission is actually the TSS/OSS sensors, which coordinate input and output speeds.
A much less frequent issue is the torque converter.
The least frequent issue is burnt clutches.
So the Service light (wrench) comes on? Do you have a pic of the lights at the time by any chance? I am thinking its most likely the TSS/OSS sensors that need to ber replaced, along with a complete drain/fill of the fluid. Could be a vacuum leak also, but doesn't sound like it.
  • 4 years later...
  • 9 months later...
