fullmotionht Posted February 12, 2017 Report Share Posted February 12, 2017 sent you a PM kiki21. are you in Canada and have an Edge that was made in China? Your location shows Montreal. Quote Link to comment Share on other sites More sharing options...
kiki21 Posted February 12, 2017 Report Share Posted February 12, 2017 On 2/12/2017 at 6:21 AM, fullmotionht said: sent you a PM kiki21. are you in Canada and have an Edge that was made in China? Your location shows Montreal. No, I'am in China and have a Ford Edge made in China. The main reason I regisrated as in Canada Montreal just because there is no any option of China, and I had been in there. BTW, would you please attached a photo of gateway module here, since I have checked on my car, there is gateway module A but when I remove the cover of the steering colum, I find the socket of this module (whose part number is G1GT-14F642-AA) is different from what I saw in the video. therefore I don't know it could work or not! Quote Link to comment Share on other sites More sharing options...
ian whu Posted February 12, 2017 Report Share Posted February 12, 2017 Kiki, type that part number into Google, the connector u see if the obd, the connector for the leads are on the back of it, Quote Link to comment Share on other sites More sharing options...
ian whu Posted February 12, 2017 Report Share Posted February 12, 2017 (edited) This is the back of it Edited February 12, 2017 by ian whu Quote Link to comment Share on other sites More sharing options...
ian whu Posted February 12, 2017 Report Share Posted February 12, 2017 And this is the front Quote Link to comment Share on other sites More sharing options...
kiki21 Posted February 13, 2017 Report Share Posted February 13, 2017 On 2/12/2017 at 3:45 PM, ian whu said: This is the back of it Thanks a lot Ian Whu, if the back side picture is as clear as front side, it would be perfect! Quote Link to comment Share on other sites More sharing options...
12voltSolutions Posted February 14, 2017 Report Share Posted February 14, 2017 If yours looks like that Kiki21, then my kit will fit. But the real question is.. will it work Quote Link to comment Share on other sites More sharing options...
kiki21 Posted February 14, 2017 Report Share Posted February 14, 2017 On 2/14/2017 at 4:03 AM, 12voltSolutions said: If yours looks like that Kiki21, then my kit will fit. But the real question is.. will it work I am waiting for Ian's come out, if his works, I think mine should also work, and the dealer promise to get refund if it does not work Quote Link to comment Share on other sites More sharing options...
ian whu Posted February 14, 2017 Report Share Posted February 14, 2017 I will fit on Sunday, am on vaction at mo, Quote Link to comment Share on other sites More sharing options...
kiki21 Posted February 14, 2017 Report Share Posted February 14, 2017 On 2/14/2017 at 8:14 AM, ian whu said: I will fit on Sunday, am on vaction at mo, Enjoy your vacation and Happy Valentine's day! Looking forward for your final verification. Quote Link to comment Share on other sites More sharing options...
nittanydoug Posted June 2, 2017 Report Share Posted June 2, 2017 I have to keep an eye on these threads. I take possession tomorrow of my 2014 Edge SEL with power lift gate. I doesn't have a remote start on the key. Plus they only had one key, so I ordered 2 blank keys with the 5 button remote. I'll have to start seeing if I have a hood button. There was one identical on the dealers lot minus nav and it had remote start. Window stickers were identical down to the color and package 205a. They lost the other key and this one may be a replacement as it is. I guess I'll still have to have the dealer program the keys but I need a spare key. Any tips on which direction to go or what I should look for to see what I have already? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 2, 2017 Report Share Posted June 2, 2017 Take a look at candurin's thread here, since you have a 2011-14 Edge http://www.fordedgeforum.com/topic/17035-adding-oem-remote-start-kits-parts-explained-detailed-2011/ Quote Link to comment Share on other sites More sharing options...
nittanydoug Posted June 2, 2017 Report Share Posted June 2, 2017 Thanks. There were so many I couldn't remember which one had the most concise info. 1 Quote Link to comment Share on other sites More sharing options...
Exploder82 Posted June 16, 2017 Report Share Posted June 16, 2017 On 10/4/2016 at 4:06 AM, solodogg said: Definitely can enable remote start with Forscan, i've done it with my 2015 SEL. Remote start is now enabled, and options can be controlled via the IPC. All I need to do is find a key, and see if it works without adding the antenna how did you enable it? Is the option in forscan to turn it on or off? If not, what settings need changed? Quote Link to comment Share on other sites More sharing options...
Gortty-Pilot Posted July 4, 2017 Report Share Posted July 4, 2017 With Forscan in the following order: In the BCM change (leave the Xs or ...s alone) 726-19-01: 0148 XXXX XXXX -Enabled 0047 XXXX XXXX -Disabled In the IPC Module change to either 720-01-03: C8F3 XXXX XXXX - base model Or F823 .... .... climate seats only Or FC27 .... .... climate seat & heated steering wheel This is per an Explorer 2011-2015 spreadsheet that I've used and apoears to be confirmed by Exploder82 2 Quote Link to comment Share on other sites More sharing options...
Burgie189 Posted January 6, 2018 Report Share Posted January 6, 2018 Has anyone followed through and bought the remotes, programmed and confirmed they work to remote start after activating remote start in the IPC? Quote Link to comment Share on other sites More sharing options...
Guest Joed Posted July 26, 2019 Report Share Posted July 26, 2019 I have purchased a 5 button remote, successfully programmed it to the car, and enabled remote start with forscan. The key will work to start the car, but only if the key is laying in the programming slot in the center console. It will not start the car if it is out of there and also none of the buttons on the remote work. The FOB battery is good and if I try to remote start the car I get a blinking red light indicating that the FOB couldn’t communicate with the car. I have heard that I need a different antenna since the 5 button remotes operate on a different frequency, but also saw that ford sells several different keyless entry transceivers for the car(different frequencies). However, my boss told me that when he bought the car new there was another lady who was buying the same car and wanted remote start. He said that right in front of her, the dealer plugged their computer in and enabled remote start and gave her 2 new 5 button remotes. Trying to figure out where to go from here. The car is a 2017 Edge SEL. Quote Link to comment Share on other sites More sharing options...
Barry F Posted November 20, 2019 Report Share Posted November 20, 2019 Left: FCC: M3N-A2C93142300, PN: 164-R8163 Freq: 315 Right: FCC: M3N-A2C931426, PN: 164-R8182 Freq: 902 I have the same story as Guest Joed, except I purchased a 4 button remote as pictured. I just noticed the frequencies and realize that I am out of luck going this route. I guess I have to buy the add on module? Quote Link to comment Share on other sites More sharing options...
