gjb89's 2015 Sport Build
gjb89
How much boost does a stock 2.7 make? And how much does it make with the LMS 93 tune? I've been wanting a boost gauge and want to utilize as much of the gauge sweep as possible. Like if the car makes 22psi, Ill get a 25psi gauge or whatever is closest. Rather than it making 22psi and having a 60psi gauge. But Ive never come across any actual boost numbers.
Edited by tmarsh
  On 9/28/2016 at 5:20 PM, gjb89 said:
--2015 Sport White Platinum Metallic--
Exterior Cosmetic
- JDM Astar 7440 Amber Leds
I'd like much brighter front turn signal lamps and would really appreciate some advice on using these LED's
The front turn signals go from dim to blinking - will these work the same, just brighter?
If not, what modifications are needed to use these turn signal LED's ?
