Tiffany Posted March 4, 2008 Report Share Posted March 4, 2008 when i close or just crack the sun shade it start to rattle. started today and does it around 45 degrees plus, when i fully open the sun shade, it is fine Quote Link to comment Share on other sites More sharing options...
solas989 Posted March 4, 2008 Report Share Posted March 4, 2008 (edited) Sounds like warranty work to me. 07-16-11 ROOF OPENING PANEL SQUEAK/RATTLE Some 2007 Ford Edge and Lincoln MKX vehicles equipped with a roof opening panel may exhibit a rattle or squeak from the rear glass area. This may be caused by the delamination of the rear trim ring hook and loop (Velcro) adhesive. Inspect the rear trim ring and if loose, determine if the loop tape has delaminated from the plastic trim ring. It may not exactly match - but reason enough to bring it in. YOu did not mention year but... Mine does not rattle - have had temps from 5F to 65F and nothing yet *knock on head* Solas Edited March 4, 2008 by solas989 Quote Link to comment Share on other sites More sharing options...
