jasoneg Posted September 23, 2016 Report Share Posted September 23, 2016 Having an engine vibration at idle and around 2500-3500 rpms in certain gears. I had the transmission torque mount replaced today, It was definitely bad, the rubber was all torn up. Still having vibrations though. (not as bad) Thinking it needs motor mounts too? It has 185,000 miles. How many motor mounts are there??? Seems hard to find on internet, and pricing is all over the place! I know they cost more but I would much rather use Ford parts. Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 23, 2016 Report Share Posted September 23, 2016 The engine & transmission are held together by 3 mounts. Front one is the Engine mount, rear is the transmission mount, and at the bottom is the torque arm (mount). With such high mileage , did you change the spark plugs? They could also cause some vibrations. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 23, 2016 Report Share Posted September 23, 2016 Definitely use OEM motor mounts. Used a NAPA mount on a ford one time, thought I was driving a WWII army truck afterwards. Noisy, rock hard, vibrations, nothing like the original. Popped it off and put on a Motorcraft, instantly turned quiet and smooth. Learned my lesson. Quote Link to comment Share on other sites More sharing options...
jasoneg Posted September 23, 2016 Author Report Share Posted September 23, 2016 I have already done the torque arm mount. So I guess I have to get the other two. I changed plugs twice, once at 80k and again at 140k. I have cleaned the fuel injection system cleaned twice as well. Drives super smooth except at that rpm range of 2500-3500 in 4th an 5th gear pretty much. A little vibration at idle, but is much better since the torque mount was replaced. I just don't know what else could make that vibration. As soon as it shifts and the rpms drop it smooth as silk. Just weird. I will definitely get the Ford mounts! Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 24, 2016 Report Share Posted September 24, 2016 Most likely the mount below the battery box is the one that is causing your issues. Not real difficult to replace just need to remove the airbox and battery tray. Should open it up for replacement. 1 Quote Link to comment Share on other sites More sharing options...
jasoneg Posted September 24, 2016 Author Report Share Posted September 24, 2016 Most likely the mount below the battery box is the one that is causing your issues. Not real difficult to replace just need to remove the airbox and battery tray. Should open it up for replacement. I watched your video about checking motor mounts. Your engine seems to move much more than mine. I had my wife rev the engine and it only moved maybe a 1/2" back and forth, so maybe an inch total, maybe. Do you think that vibration could be something else? Also is that mount considered the right or left? btw I have the "orange crush" as well ! Best color ever ! Thanks for your help! 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 24, 2016 Report Share Posted September 24, 2016 I watched your video about checking motor mounts. Your engine seems to move much more than mine. I had my wife rev the engine and it only moved maybe a 1/2" back and forth, so maybe an inch total, maybe. Do you think that vibration could be something else? Also is that mount considered the right or left? btw I have the "orange crush" as well ! Best color ever ! Thanks for your help! The lower mount on the Drivers side seems to be the one that fails most if it fails. My Engine moved a lot because of the transmission torque mount below had failed. Plus the noise you heard was as it turned out to be a broken passenger side sway bar link. That Orange Crush had a hard life. LOL 1 Quote Link to comment Share on other sites More sharing options...
jasoneg Posted October 6, 2016 Author Report Share Posted October 6, 2016 I asked the shop i normally take my car to and they said there are 2 motor mounts a trans mount (under the airbox) and the torque mount (which i have replaced) Is that correct? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 6, 2016 Report Share Posted October 6, 2016 (edited) https://secure.revolutionparts.com/levittown-ford/auto-parts/2010/ford/edge/sel-trim/3-5l-v6-gas-engine/engine-cat/engine-and-trans-mounting-scat No. Part # Description List Price Price 1 8T4Z-6038-A FRONT MOUNT, RIGHT $175.90 $121.37 2 7A1Z-6038-AA FRONT MOUNT, LEFT $136.23 $94.00 3 8M8Z-6038-A ENGINE BRACKET, RIGHT $55.67 $38.41 4 8T4Z6031B ENGINE BRACKET, LEFT - - 5 -W711873-S439 ENGINE BRACKET BOLT $4.25 $2.45 6 -W711872-S900 ENGINE BRACKET NUT $3.00 $1.73 7 7T4Z-6K075-BA UPPER SUPPORT $7.47 $5.15 8 7T4Z-6K075-AA LOWER SUPPORT $10.00 $6.90 9 8T4Z-6068-B TRANS MOUNT FROM 1/11/08 $91.53 $63.16 10 7T4Z-6C038-A HEAT SHIELD $20.78 $14.34 11 7T4Z-6E042-AA BRACKET $19.58 $13.51 Edited October 6, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
jasoneg Posted October 14, 2016 Author Report Share Posted October 14, 2016 It was the Transmission mount under the airbox! Had it replaced today and its smooth as silk. Thanks everyone! 1 Quote Link to comment Share on other sites More sharing options...
Prolyphix74 Posted October 17, 2024 Report Share Posted October 17, 2024 I'm planning on replacing all 3 mounts. I know I should get oem but should I get them from a good dealership or is there another cheaper route that isn't aftermarket? Appreciate the help. Thanks! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 2, 2024 Report Share Posted November 2, 2024 Use RockAuto as your base, then check Levittown Ford. https://parts.levittownfordparts.com/?gad_source=1&gclid=Cj0KCQjwm5e5BhCWARIsANwm06jv6lt2YUw3H_-qOUFO9e0xocYRw8sTbDr03pDXDCXnOSb2zOtg6Y8aAmpoEALw_wcB 1 Quote Link to comment Share on other sites More sharing options...
