Intermittent Park Aid Sensor Fault Message Or Ambient Air Temperature (AAT) Incorrect – 2015-2016 Ford Edge & 2016 Lincoln MKX
WWWPerfA_ZN0W
oemdtc September 5, 2016
2015-2016 Edge – 2016 MKX – Intermittent Park Aid Sensor Fault Message Or Ambient Air Temperature (AAT) Incorrect With Or Without Inoperative A/C
Some 2015-2016 Edge and 2016 MKX vehicles may exhibit an intermittent park aid sensor fault message illuminated in the instrument panel cluster (IPC) message center or an AAT that intermittently reads incorrectly with or without inoperative air conditioning (A/C).
If water intrusion is found in wiring connector C140, service pigtails EU2Z-14S411-VA (male) and CU2Z-14S411-ADA (female) have been released.
Replacement of wiring harness 15K867 (male) or 14K733 (female) is no longer necessary when either of these connectors require servicing.
Service Pigtail (Male) EU2Z-14S411-VA
Service Pigtail (Female) CU2Z-14S411-ADA
