VisionPilot Posted September 15, 2016 Report Share Posted September 15, 2016 Even though I have a '16 MKX, I'm going to assume that this function is similar. I cannot figure out how to turn off the rear cargo area lamps when one of the 4 passenger doors is opened. Turning off the passenger area dome lights is done via a toggle button in the overhead console, but this does not disable the two lamps in the hatch area. Is this an issue with the '15+ Edge? Quote Link to comment Share on other sites More sharing options...
James Costa Posted September 15, 2016 Report Share Posted September 15, 2016 Even though I have a '16 MKX, I'm going to assume that this function is similar. I cannot figure out how to turn off the rear cargo area lamps when one of the 4 passenger doors is opened. Turning off the passenger area dome lights is done via a toggle button in the overhead console, but this does not disable the two lamps in the hatch area. Is this an issue with the '15+ Edge? Hi VisionPilot, I have a 2016 Edge and the issue is the same. Even with the interior lighting toggle off, the cargo area light still comes on. Haven't run across any ways to modify said behavior. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 15, 2016 Report Share Posted September 15, 2016 If you dont ever want it on, just pull the bulb? Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 17, 2016 Report Share Posted September 17, 2016 Probably not want your looking for, but you can have dealer enable a feature called "dark mode" it's made for police vehicles but basically kills all the interior lights when a door is opened. Does seem strange that there's no way to shut that light off, although I don't know why you'd need it off either? Seems like a fringe case nobody in engineering bothered with. Just curious as to why you want this shut off? Probably best bet was listed above, pull the bulb Quote Link to comment Share on other sites More sharing options...
jmr061 Posted September 17, 2016 Report Share Posted September 17, 2016 Install a kill switch? Quote Link to comment Share on other sites More sharing options...
All Hat No Cattle Posted September 18, 2016 Report Share Posted September 18, 2016 I would want to be able to kill the cargo area lights when I go camping, and forget something in the back. Opening the hatch and having the lights come on will ruin your night vision for a while. A flashlight does not do that. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted September 18, 2016 Report Share Posted September 18, 2016 You could simply disable the "hatch open" switch so that the lights would not turn on. Or you could install a switch for either just the cargo area lights or for all courtesy lights depending on your needs. Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 18, 2016 Author Report Share Posted September 18, 2016 You could simply disable the "hatch open" switch so that the lights would not turn on. Or you could install a switch for either just the cargo area lights or for all courtesy lights depending on your needs. The two hatch area lights come on when one of the front doors open, how will disabling the hatch switch affect that situation? Quote Link to comment Share on other sites More sharing options...
TheWizard Posted September 18, 2016 Report Share Posted September 18, 2016 (edited) My comment was directed at All Hat No Cattle who said that opening the hatch and having the lights come on would ruin his night vision (the post immediately preceding mine). If that was the only situation where he wanted to disable the lights then disabling the hatch switch would accomplish exactly that. Edited September 18, 2016 by TheWizard Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted September 18, 2016 Report Share Posted September 18, 2016 I would want to be able to kill the cargo area lights when I go camping, and forget something in the back. Opening the hatch and having the lights come on will ruin your night vision for a while. A flashlight does not do that. Put tape over it. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 19, 2016 Report Share Posted September 19, 2016 This is a car forum after all...PLASTI DIP THE LIGHT :) 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 19, 2016 Report Share Posted September 19, 2016 (edited) I second duct tape LOL. Or nail polish plastidip is too easy. Edited September 19, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 19, 2016 Author Report Share Posted September 19, 2016 Ok, so how does one remove the lenses to get to the bulbs, do you pinch them off from the ends or the sides, or do the panels need to come off? Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 20, 2016 Report Share Posted September 20, 2016 I'd have to imagine it's a pop off cap, most interior lights are. I'd look alon the edge of it for any type of indentation or little change it the lense. That's probably where you wanna start prying at it. Might need a small flathead screwdriver to help. I find the ones in a eyeglass case are delicate and small enough for these type jobs myself 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 21, 2016 Report Share Posted September 21, 2016 Ok, so how does one remove the lenses to get to the bulbs, do you pinch them off from the ends or the sides, or do the panels need to come off?It's a 2016 right? Non-serviceable LED lamp. Replaced an an entire assembly I believe. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted September 21, 2016 Report Share Posted September 21, 2016 It's a 2016 right? Non-serviceable LED lamp. Replaced an an entire assembly I believe. He's right I remember reading this in the manual. I believe it's stated on the bulb size chart if you look for that in manual index. There's a few other lights like this as well. The only downside to LEDs I've ever found so far. But then again with bulb life dramatically increased it may never be an issue in my lifetime with the vehicle Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 21, 2016 Author Report Share Posted September 21, 2016 It's a 2016 right? Non-serviceable LED lamp. Replaced an an entire assembly I believe. Well that sucks. I truly find it annoying that those two cargo area lamps always come on whenever ANY door is open, and sometimes, when simply stopping the car, irrespective of whether the dome light toggle in the overhead is off. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 22, 2016 Report Share Posted September 22, 2016 If you only need to blank the lights out on rare occasions .... put duct tape over them. Camouflage duct tape of course. lol Quote Link to comment Share on other sites More sharing options...
