mattA Posted September 9, 2016 Report Share Posted September 9, 2016 Recently bought my 2012 ford edge 3.5 and have replaced more parts than I wanted to! Ive changed the throttle body, o2 sensors, transsmiss lines power steering pump and a couple of other small things! BUT the issue I'm having is it's rough on start up/idle but fine once she in drive, it occasionally shuts off and says low engine oil pressure. If anyone els has a solution or has had the same problems PLEASE help! TIA Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 10, 2016 Report Share Posted September 10, 2016 Could simply need a recalibration of the PCM and or the instrument cluster. But the fact that there are issues on startup/idle says you should look deeper. Do you change your own oil/filter or do you have it done? Has this been going on over multiple oil changes? Could be too little oil, incorrect oil viscosity, a bad oil filter, etc. How does the oil look, does it get dirty quickly? 5W20 Motorcraft Synthetic Blend, Motorcraft FL500S oil filter at a minimum. May take between 5-6 quarts of fresh oil at change time. Quote Link to comment Share on other sites More sharing options...
Dogg Posted May 12, 2018 Report Share Posted May 12, 2018 HELP!!! Can someone please advise how my I locate the Engine Number on a 2016 Ford Edge Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 12, 2018 Report Share Posted May 12, 2018 (edited) Which engine do you have? BTW, did you check the registration document or the vin number plate? Edited May 12, 2018 by enigma-2 Quote Link to comment Share on other sites More sharing options...
akirby Posted May 12, 2018 Report Share Posted May 12, 2018 What exactly do you mean by Engine number? 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 13, 2018 Report Share Posted May 13, 2018 (edited) Ford cast a engine number in the block which describes the model and serial number. They also attach a tag to engine with this information. This link describes various locations, but may by old information. https://www.wikihow.com/Identify-a-Ford-Motor Edited May 13, 2018 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
Dogg Posted May 13, 2018 Report Share Posted May 13, 2018 Thanks Enigma-2, but as you suggested the link was dated. My trim is the 2016 Ford Edge SE with the 2.0L engine. I'm currently in Jamaica (with the Edge), and need to get it inspected (similarly to the US's DMV), however in Jamaica they also verify the VIN and Engine Number. I know it's on the Engine Block someplace, and I'm trying to avoid going to the Ford Dealer for their confirmation, as it's not in the Owner's Manual I need to know if I need to remove the engine cover, or if it's visible with the cover on. Your guidance in this matter would be very appreciative. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 14, 2018 Report Share Posted May 14, 2018 (edited) On 5/13/2018 at 11:36 PM, Dogg said: Thanks Enigma-2, but as you suggested the link was dated. My trim is the 2016 Ford Edge SE with the 2.0L engine. I'm currently in Jamaica (with the Edge), and need to get it inspected (similarly to the US's DMV), however in Jamaica they also verify the VIN and Engine Number. I know it's on the Engine Block someplace, and I'm trying to avoid going to the Ford Dealer for their confirmation, as it's not in the Owner's Manual I need to know if I need to remove the engine cover, or if it's visible with the cover on. Your guidance in this matter would be very appreciative. "The engine code information label, located on the rear of the vacuum pump and on the LH valve cover...", check this documents. Thanks to @MacT & his site: https://www.mactgarage.com/ Edited May 14, 2018 by omar302 1 Quote Link to comment Share on other sites More sharing options...
Shannonhb Posted May 17, 2018 Report Share Posted May 17, 2018 Im sorry to hear youre in the same boat. But Get used to it. There is a lot more to come! If its drivable and you can manage it, SELL IT!!!! Trade it in. Do whatever you need to to get out of that car!!! Good luck. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 17, 2018 Report Share Posted May 17, 2018 On 5/12/2018 at 3:07 PM, Dogg said: HELP!!! Can someone please advise how my I locate the Engine Number on a 2016 Ford Edge I just dicovered that the engine number is also on a production traveler that's stuffed behind the hood acoustic blanket (under the hood). On mine, it was shoved on the side on the drivers side. 1 Quote Link to comment Share on other sites More sharing options...
