Newless Posted September 8, 2016 Report Share Posted September 8, 2016 Hey folks. I just got a bluedriver last night. Ran some scans and found a p0480. Cooling fan 1 circuit. No check engine light one. But looking under the hood I see the drivers side fan is not running, in hot weather, with the A/C on. Anyone else deal with this problem? I have seen some fixes involving the a/c selector switch, but im not sure how to test that switch. Thx! Ill post fix when I figure it out but looking for direction. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2016 Report Share Posted September 8, 2016 You have to replace the fans and controller module. Very common problem. http://www.fordedgeforum.com/topic/12731-radiator-fan-assembly-replacement-procedure/page-4?hl=%20cooling%20%20fan Post 62 has a video. 1 Quote Link to comment Share on other sites More sharing options...
Newless Posted September 8, 2016 Author Report Share Posted September 8, 2016 Thx for quick reply! I was afraid of that. Ill look into prices on that unit. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2016 Report Share Posted September 8, 2016 Note that the generic brands like Dorman have not worked for some people. I used a Dorman and it worked fine but we traded the vehicle soon after. Others have not gotten them to work at all and ended up buying the motorcraft version. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 10, 2016 Report Share Posted September 10, 2016 Note that the generic brands like Dorman have not worked for some people. I used a Dorman and it worked fine but we traded the vehicle soon after. Others have not gotten them to work at all and ended up buying the motorcraft version. Agree go OEM and then forget about it. You will be happier. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 10, 2016 Report Share Posted September 10, 2016 I had my 09 fans replaced in late August. Covered under the extended warranty but the told me the bill would have been between $700 & $800. (However they also evacuated the ac and recharged as the high side was a little low, told me it was common to lose a little refrigerant over the years). So probably closer to the $700 figure at a ford dealer. 2 Quote Link to comment Share on other sites More sharing options...
Newless Posted September 11, 2016 Author Report Share Posted September 11, 2016 Ok so this is what happened today. First I called the Ford dealer for the Motorcraft unit. Here in Canada it's $739 after tax. So Im about to order it off of RockAuto. This morning I decided to test power and ground to the fans. I take out the airbox and remove two of the connectors and both are getting power and ground. So I figure its the fan itself. Put it all back together and suddenly the drivers side fan is working again! I have been driving it and let it sit in the driveway, so far so good. I have heard of another owner having the same thing happen. Thoughts?? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 11, 2016 Report Share Posted September 11, 2016 Maybe it was just the connections. But I'd be prepared to find a replacement fan assembly anyway, just in case. Quote Link to comment Share on other sites More sharing options...
Newless Posted September 11, 2016 Author Report Share Posted September 11, 2016 Ill keep this updated and let people know if in the short term it does stop working again. 2 Quote Link to comment Share on other sites More sharing options...
Newless Posted September 14, 2016 Author Report Share Posted September 14, 2016 So here is an udate for people with the same problem. My drivers side fan has stopped again. But can be made to work again by shaking the wires or tapping the motor with a wrench. So the new fan system is ordered. $350 with rockauto. Let you know how things go. 2 Quote Link to comment Share on other sites More sharing options...
