Nickmatt5692 Posted September 8, 2016 Report Share Posted September 8, 2016 Recently bought a 2014 Ford Edge from an Ford dealership. I noticed some slight rust while test driving the car and asked the salesman about it and he stated that it was normal, because of the coating Ford puts on. When I got home I noticed that it has quite a bit of rust. https://imgur.com/gallery/pCgoX Do you think this is normal? Carfax/title is clean. One owner from Michigan. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 8, 2016 Report Share Posted September 8, 2016 Wow, that is a LOT, but knowing that the Edge is from Michigan, quite possibly "normal". How many miles on the Edge? I am surprised there are no rust spots on the hood, at/near the chromework, etc. The previous owner definitely did not wash their vehicle regularly, which is a must in states that salt roads for the winter ... Don't be surprised if you have brake work ahead as well. Quote Link to comment Share on other sites More sharing options...
Nickmatt5692 Posted September 8, 2016 Author Report Share Posted September 8, 2016 It has 38k miles on it. That's really why I didn't notice it, the body and interior are flawless. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 8, 2016 Report Share Posted September 8, 2016 Then its likely the undercarriage was never washed. If it was, the salt would not have a chance to accumulate and cause the damage you posted about. Some (surface) rust is of course going to happen regardless. It happens on the brake rotors, but the rotors get scraped clean every time you brake. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2016 Report Share Posted September 8, 2016 Clean it really well, use a wire brush to get most of it off and then hit it with some rust converter coating. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted September 8, 2016 Report Share Posted September 8, 2016 If you do all that, then go ahead and paint it. Rust converter should be top coated. That's pretty bad for a 2014, but it could have seen the winter of 2013, 2014, and 2015 before you got it. 3 years in Michigan, depending on where, can easily case the rust you are seeing. Most of it looks to be on heavy pieces of steel- the subframe, control arm, strut bodies, so it's really all just "surface rust" when you consider how much steel is left. Rust on the thin body panels is way more of an issue- the bottoms of doors/hood/liftgate, wheel wells, rockers and floor pans are what you need to really keep an eye on. Quote Link to comment Share on other sites More sharing options...
factor99 Posted September 8, 2016 Report Share Posted September 8, 2016 (edited) Here, where your vehicle is coated in fine salt 5 minutes after it is washed most of the winter, this is a fairly normal looking undercarriage. All that area is pelted with whatever is on the road, damaging the minimal paint on it. I don't think suspension rust causes many problems,and though brake rotors can get very rusty on the non-wearing surfaces, they usually keep working fine (getting bolts off can be another story though). Years ago I did have a brake line rust through on a 15 year old Toyota. Edited November 1, 2016 by factor99 Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2016 Report Share Posted September 8, 2016 Years ago I did have a brake line rust through on a 15 year old Toyota. Could have been worse. 3 Quote Link to comment Share on other sites More sharing options...
Liptoss Posted October 11, 2016 Report Share Posted October 11, 2016 This is my second Ford in the last 10 years. My first was a 2008 Focus. It's systemic, it seems. Fords seem to be rust buckets after a few years. Then again, it could be many manufacturers. I notice MAZDA has loads of rust too? Hmmmm I bought a 2013 off a Ford dealer lot last March. It was a 2013 which was on the road in 2012. So, 2 winters before I bought it. Mine under carriage is pretty much rusted up like yours. P/O didn't take of it much care I'm guessing. YUP! I just replace all brakes (rotors, pads, pins etc) all around. Rotors were flaking and lunching themselves. MY issue now is with the seams on the 2 rear doors and the back hatch. On the doors it's not along the bottom rocker panel edge but up along the curve of the wheel well. The seam edge on the back gate is all along the bottom. It's rust bubbling under the paint. UNACCEPTABLE for a 4 year old vehicle. I've had a dealer spray Rust Check in all the doors and panels last fall, but it looks like it's too late. Garbage rolled steel that has been specified I've been told... heh. That's another story. I'm hitting it with doses of Rust Check on my own now, hopefully it'll hold off at least until I can dump it for a new vehicle. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 11, 2016 Report Share Posted October 11, 2016 I've never had a bit of rust on any of my Fords for the last 25 years. Then again we don't get snow, ice and salt in the wintertime. Any vehicle is going to rust in those conditions without proper maintenance/cleaning. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 11, 2016 Report Share Posted October 11, 2016 Just noticed a chip in the paint at the leading edge of the hood. If I had not run my hand along the edge to check, would never have noticed it. Time to prime/paint ... Quote Link to comment Share on other sites More sharing options...
fishx65 Posted October 12, 2016 Report Share Posted October 12, 2016 That's pretty normal in the salt belts of Michigan. The previous owner probably parked it in an attached garage which makes salt damage even worse. Quote Link to comment Share on other sites More sharing options...
scorpionking0102 Posted October 30, 2016 Report Share Posted October 30, 2016 I pretty much agree with all of your replys. THATS A LOT OF RUST for a 2014. You could possibly take it to your local Ziebart dealer. I once called one becaused I had a Mazda Tribute rusting and they say their sprays have converters in them. It was about $350 though. That's only what the Ziebart guy told me and not my opinion. Quote Link to comment Share on other sites More sharing options...
Liptoss Posted November 3, 2016 Report Share Posted November 3, 2016 Not normal for doors and body, probably low grade sheet metal from specifications given to suppliers. Quote Link to comment Share on other sites More sharing options...
bubbadewsky Posted November 7, 2016 Report Share Posted November 7, 2016 (edited) I have a 2014 Edge only been in salt once. I washed the undercarriage after, it has no rust. I would wash that undercarriage very well and apply a coat of heavy oil on the rust..............will be ok for atleast 30 yrs. Years ago we used to get an oil can and squirt the undercarriage then drive down a dusty dirt road rust was never a problem then. I found that undercoating peels after a few years then the peeled sections become traps for salt Edited November 7, 2016 by bubbadewsky Quote Link to comment Share on other sites More sharing options...
lildisco Posted November 7, 2016 Report Share Posted November 7, 2016 Used a product called fluid film for years. Multiple different vehicles that helps prevent a lot of salt/brine from reaching the the frame, brake lines, etc. My brother in law & I spray about 10+ vehicles a year for the last 4-5 years,ranging from a rusted 97 blazer, 2002 ford focus, 2003 Toyota Tacoma to a 2015 Toyota 4 Runner & i spray our '16 Edge. Very little, if any, rust exists on those vehicles. Fluid film absorbs into the metal/rust & gives it a protective layer from the elements. I sprayed the Edge as soon as we got it in March & then again a few weeks ago to prepare for winter. I just sprayed in & around the wheel wells tonight when i was swapping to the winter wheels. Google it when you get a chance. It's worth your time to watch some of the videos about it. http://www.fluid-film.com https://m.lowes.com/pd/Fluid-Film-11-75-oz-Fluid-Film-Rust-Corrosion-Preventive-Penetrant-Lubricant/50335157 http://lmgtfy.com/?q=Fluid+film+reviews 1 Quote Link to comment Share on other sites More sharing options...
2FAST4U Posted November 7, 2016 Report Share Posted November 7, 2016 I've been rustproofing all my vehicles for years with an oil-based stuff which gets into every nook and cranny and never had any rust problem. Works great and is a good investment if you intend to keep your car for a long time. There are several companies here in Canada who specialize in these kinds of rustproofing treatments. Claude. 1 Quote Link to comment Share on other sites More sharing options...
IWRBB Posted November 7, 2016 Report Share Posted November 7, 2016 Used a product called fluid film for years. Loves me some fluid film, but it reeks. Takes a good few months to go away. Quote Link to comment Share on other sites More sharing options...
lildisco Posted November 8, 2016 Report Share Posted November 8, 2016 (edited) Loves me some fluid film, but it reeks. Takes a good few months to go away. Never had it last for months, a week & a few days yes. Depends on how much you drive i guess. Edited November 8, 2016 by lildisco Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 8, 2016 Report Share Posted November 8, 2016 My 2009 MKX still has no body rust, dispite having been registered in Michigan, Ohio and Indiana since new. The roads here in Northern Indiana are particularly bad for rusting in winter months as they switched to a salt slurry a few years ago to start the melting process faster. Eats cars alive however. I use an electronic rust control module, the one that pulses high frequency radio waves. Been on since new. First owner installed when the MKX was new and then took it with him when he bought a new MKX. When I bought it used, I had the same model module put on. Seems to be working as there's no rust on any body panel (including underbelly.) As I understand it, the module only works to prevent rust on galvanized parts. (Comes with a warranty against surface rust and rust through.) Quote Link to comment Share on other sites More sharing options...
IWRBB Posted November 8, 2016 Report Share Posted November 8, 2016 Electronic rust protection is BS. It would work fine if you had a path to ground. However, given that cars sit on rubber tires- all they do is separate you from your money. If they worked, everyone would have them. For the record, cathodic protection obviously does work- but those add on anti-rust boxes for your car DO NOT. 7 years is still a bit young for most Fords to show rust on the body panels themselves. You might see bubbles at the door seams though. I can guarantee there's all kinds of rust on your subframe, suspension parts, brakes, engine/suspension nuts and bolts, exhaust parts, heat shields, etc.. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 8, 2016 Report Share Posted November 8, 2016 I agree for most of the current tenders I've seen, the jury is out on this system. As I stated, it only protects galvanized sheet metal parts, so seeing corrosion on bare steel parts is no surprise. For a car in a heavy salt slurry area, I yet to see any rust on the belly or anywhere else. So for now I'm still thinking that it might be doing something. The principal of operation is patented. The man that discovered it noticed an old galvanized steel storage tank completely untouched fy rust (while others in the area were.) Being an engineer, he investigated and found the one which was not rusted was being protected by a local radio tower which was inducing currents in the steel. He found that when galvanizing finally breaks down, the zinc will naturally sacrifice itself and slow down the corrosion process. However moisture in the air reacts with the zinc and cause zinc to form zinc oxide. Zinc oxide tends to block zinc from forming across the break and will allow corrosion to form on the unprotected steel. The module generated a pulse to create a radio frequency current in the metal which is supposed to neutralize the oxide from forming. So far (seven years) I'm pleased with the result; but time will tell. 1 Quote Link to comment Share on other sites More sharing options...
David Young Posted November 10, 2016 Report Share Posted November 10, 2016 When i was a child in the 1960's we could always tell when we saw a 2 or 3 years old car with rust holes in the body, we knew that car was from Ohio or Michigan That is a lot of rust for a 2014 Quote Link to comment Share on other sites More sharing options...
Liptoss Posted January 12, 2017 Report Share Posted January 12, 2017 Been looking at many other 2013 units being driven in the same areas as myself. NOPE none of them have any issue of bubbling paint along the rear door seams or along the back lid lower seam. Cheap crap that's all. I'll chalk this one up. JUST LIKE THE CRAPPY FOCUS rocker panels of years gone by. I'll deal with it, it's ok. I'll keep it in the back of my mind for my next purchase of a vehicle though. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted January 13, 2017 Report Share Posted January 13, 2017 Never had it last for months, a week & a few days yes. Depends on how much you drive i guess. Depends on how much was used, and in what locations. If you spray it inside your doors and the lower seam, you'll smell it for a good long while, especially in the summer. Quote Link to comment Share on other sites More sharing options...
