gjb89 Posted August 31, 2016 Report Share Posted August 31, 2016 Anyone using this? Do you get the suction sound like you do with a CAI? Quote Link to comment Share on other sites More sharing options...
unca waldo Posted August 31, 2016 Report Share Posted August 31, 2016 If the Edge intake system is like any other car I've owned, merely changing to a K&N drop in filter, will not increase to sound the intake produces. Factory intake systems are designed to be quiet... 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2016 Report Share Posted August 31, 2016 A BOV mod might be what you are looking for if you want to hear the turbos. Otherwise, there will be a tiny bit of gain with the dropinfilter, but nothing like with the metal bodied CAI. 1 Quote Link to comment Share on other sites More sharing options...
gjb89 Posted August 31, 2016 Author Report Share Posted August 31, 2016 Thank you. Had a CAI on a past car and wasn't very fond of the sound. Just wanted to check before committing to buying the drop in. Quote Link to comment Share on other sites More sharing options...
junehhan Posted September 1, 2016 Report Share Posted September 1, 2016 I am like a broken record, but I recommend avoiding oiled filters like this. Do a search as there are plenty of tests which show that K$N's are not what people think. When clean, they have much lower filtering efficiency which means you let not just more dirt into the engine, but also bigger sized particles. Tests also show that flow resistance goes up drastically as the filter becomes dirty. 1 Quote Link to comment Share on other sites More sharing options...
Burrcold Posted September 1, 2016 Report Share Posted September 1, 2016 I hate oiled filters as well. 1 Quote Link to comment Share on other sites More sharing options...
gjb89 Posted September 1, 2016 Author Report Share Posted September 1, 2016 I am like a broken record, but I recommend avoiding oiled filters like this. Do a search as there are plenty of tests which show that K$N's are not what people think. When clean, they have much lower filtering efficiency which means you let not just more dirt into the engine, but also bigger sized particles. Tests also show that flow resistance goes up drastically as the filter becomes dirty. Thank you for the info Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted September 1, 2016 Report Share Posted September 1, 2016 Have a older model Edge Sport and did the K&N CAI system.... What a waste of money and its really loud with the least bit of acceleration. If I had it to do all over again..I'd just get a lifetime replacement filter to fit my vehicle Quote Link to comment Share on other sites More sharing options...
James Costa Posted September 1, 2016 Report Share Posted September 1, 2016 Anyone using this? Do you get the suction sound like you do with a CAI? Hi, I put the drop-in K&N in my Edge and find it brings a vast improvement in shifting and acceleration. it shifts smoother and with less jolt, and gives it a bit more juice. it does give the suction sound you speak of at full throttle, but it is minimal compared to a conical-style intake. at the rate i change my oil, i doesn't bother me too much if a bit of extra dirt gets through. for $50 it is a marked improvement IMO. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted September 1, 2016 Report Share Posted September 1, 2016 It's called the placebo effect...... 2 Quote Link to comment Share on other sites More sharing options...
Waldo Posted September 1, 2016 Report Share Posted September 1, 2016 Hi, I put the drop-in K&N in my Edge and find it brings a vast improvement in shifting and acceleration. it shifts smoother and with less jolt, and gives it a bit more juice. it does give the suction sound you speak of at full throttle, but it is minimal compared to a conical-style intake. at the rate i change my oil, i doesn't bother me too much if a bit of extra dirt gets through. for $50 it is a marked improvement IMO. Changing your oil won't stop the dirt from sandblasting the turbos. Sandblasted turbos will eventually fail no matter what you do with your oil. Quote Link to comment Share on other sites More sharing options...
junehhan Posted September 1, 2016 Report Share Posted September 1, 2016 It's called the placebo effect...... Exactly. K&N is nothing but snake oil with their lofty claims 30+hp and 3 mpg gains. We live in the era of cafe. If these oiled filters really offered those gains without negatively impacting the Powertrain, Ford would have been using them. Lots of tests on the Internet and especially one that the Powerstroke guys did show the truth about just how bad filtering efficiency can be. The only application where these filters have valid use is off-road crossing deep streams as the oil lowers the risk of sucking water in. Changing your oil won't stop the dirt from sandblasting the turbos. Sandblasted turbos will eventually fail no matter what you do with your oil. You beat me to it. People do not understand the insane tolerances in the turbos as they really are as tight as jet engines. It just is not worth it to get an extra 2-5hp. 1 Quote Link to comment Share on other sites More sharing options...
