ChucklesMcHaHa Posted August 18, 2016 Report Share Posted August 18, 2016 All of my displays on my daahboard,radio and climate control have gone dark. I was told it was the compass module. But for all my searches I haven't been able to find any problem, or even where the location of it is. Anyone have this problem or have any answers for me? Thanks in advance Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted August 18, 2016 Report Share Posted August 18, 2016 The compass module is the box behind the rear view mirror. I can't imagine that it would cause a problem with all of the displays. I have unplugged the module and I just don't get the compass feature. You can disconnect it from the system and see if it is causing the problem. Quote Link to comment Share on other sites More sharing options...
ChucklesMcHaHa Posted August 18, 2016 Author Report Share Posted August 18, 2016 Yeah Paul, from what I read about the compass module it didn't make any sense to me either. But on the dash board before everything went screwy said check module on the dash. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted August 18, 2016 Report Share Posted August 18, 2016 It's definitely in the mirror. I've also unplugged the connection to the mirror and only had a "compass not found" warning when the key was turned on. Everything else was fine. Quote Link to comment Share on other sites More sharing options...
Jcrock Posted yesterday at 08:12 PM Report Share Posted yesterday at 08:12 PM Compass would not calibrate. Unplugged car battery for 5 minutes, reconnected. Everything works except compass. Does not even bring up calibrate function in setup mode. Really not needed, but where did it go? Jim 1 Quote Link to comment Share on other sites More sharing options...
