Kamikaze Posted August 17, 2016 Report Share Posted August 17, 2016 When I use my fob to unlock the car, the side mirrors shift up every time. The button on the driver side to control the passenger front window is also not working, so not sure if that's related. Any ideas? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 Do you have the three buttons for memory positions? It controls seat, wheel, and mirrors. You may have set one with mirrors adjusted one way and now when you use the fob it moves the mirrors back where you had them when you set the memory function. if you didn't set it, maybe someone else did. The manual should have instructions on how to reset the settings Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 18, 2016 Report Share Posted August 18, 2016 On mine, I adjust the mirrors, (etc.) and then lock the setting by pressing the memory switch on the door. Hold until the second beep and the setting is set for your FOB. Quote Link to comment Share on other sites More sharing options...
Kamikaze Posted August 22, 2016 Author Report Share Posted August 22, 2016 Oohh great idea. I will check that out and see. Thank you both. Quote Link to comment Share on other sites More sharing options...
