Clyde Epperson Posted August 17, 2016 Report Share Posted August 17, 2016 Brake lights are staying on? And traction control light came on? Please help Thank you Quote Link to comment Share on other sites More sharing options...
akirby Posted August 17, 2016 Report Share Posted August 17, 2016 Did you do any work at the wheels - bleeding fluid, etc.? You may have damaged/unplugged a wheel speed sensor. Quote Link to comment Share on other sites More sharing options...
Clyde Epperson Posted August 17, 2016 Author Report Share Posted August 17, 2016 No work at wheels and no need to bleed brakes. I just reset light by removing negative terminal, light went out so well see. Now I just have brake light issue. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 17, 2016 Report Share Posted August 17, 2016 Did you make sure to follow instructions for the brake light switch (below brake pedal)? NOTICE: Do not service the brake pedal or brake booster without first removing the stoplamp switch. This switch must be removed with the brake pedal in the at-rest position. The switch plunger must be compressed for the switch to rotate in the bracket. Attempting to remove the switch when the plunger is extended (during pedal apply) will result in damage to the switch. Remove the stoplamp switch. For additional information, refer to Section 417-01 NOTICE: Do not press, pull or otherwise move the brake pedal while installing the stoplamp switch. The switch must be installed with the booster push rod attached to the brake pedal and with the brake pedal in the at-rest position. Installing this switch with the brake pedal in any other position will result in incorrect adjustment and may damage the switch. Quote Link to comment Share on other sites More sharing options...
Clyde Epperson Posted August 17, 2016 Author Report Share Posted August 17, 2016 Yes followed instructions. the brake pushes the switch back in but not enough. Any idea it just a fine little amount. Quote Link to comment Share on other sites More sharing options...
Clyde Epperson Posted August 17, 2016 Author Report Share Posted August 17, 2016 The traction control light is back on after I reset it. Any ideas? Quote Link to comment Share on other sites More sharing options...
akirby Posted August 17, 2016 Report Share Posted August 17, 2016 Traction control light typically points to a wheel speed sensor. Could be totally unrelated. Quote Link to comment Share on other sites More sharing options...
Clyde Epperson Posted August 17, 2016 Author Report Share Posted August 17, 2016 How do I know which one? Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 20, 2016 Report Share Posted August 20, 2016 Did you purchase a new brake light switch for the job. If not more times than not the switch needs to be replaced also. Get an OBDII scanner and check for the sensor malfunction. Quote Link to comment Share on other sites More sharing options...
y2ksilverbullit Posted October 20, 2016 Report Share Posted October 20, 2016 Ever figure out what the problem was? I was going to ask if you thought the booster was seated properly when re-installing...?? I am getting ready to tackle this job on my 08. Any tips or tricks? I heard taking the cowl cover off makes booster removal/replacement a little easier... TIA Quote Link to comment Share on other sites More sharing options...
