Ford OBD2 scantool
junehhan
So I was able to change some BCM stuff in HS-Can mode with my cheap wifi device I hacked apart via ForScan. The hack didn't work correctly and the wiring diagrams didn't help because I had a completely different board in mine.
I want to buy another and try the fix again...anyone know or done this with a cheapo device and can confirm it has actual wires inside and not chipsets with pins?
Just learning how to solder and much easier to take a wire off than a whole chip just to remove one pin.
I'm getting close I can feel it... :)
  • 4 weeks later...
My apologies if considered hijacking this thread but a quick question. I would like to turn off the double honk when you exit a running vehicle with your key in your pocket. I've just ordered the ELM327 USB Omar suggested and have FORscan Lite on my phone. Where would be a good sourse of material to read up on turning off this piece of code? I'm a Cro-Magnon with newer vehicles so any help would be appreciated.
