junehhan Posted August 17, 2016 Report Share Posted August 17, 2016 I was curious what scantool some of you guys might be using that you might recommend that has the ability to do data logging of all variables simultaneously. The last I used was the MSD DashHawk, but it is not compatible with newer Fords. Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 17, 2016 Report Share Posted August 17, 2016 Forscan Lite and Torque Pro. Used to use OBDLink's software, stopped a year or so back. 1 Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 I am reading forscan lite correctly? I can download app and via wifi "plug" into my car from my phone? It's $5 I want to make sure I read that write before purchasing it. Or do you still need some type of connection to the vehicle? My 2016 has wifi so this sounds like that may be what it is Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 You need a connection to the OBD system, ie via the OBD port to hook up to the software. So you need to buy a Bluetooth or Wifi OBD adapter ($20 if you don't intend to leave it in all the time) and up for those. I use the OBDLink MX (bluetooth, avoid the WiFi), and have gotten 2+ years out of it so far, always plugged in. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 https://www.amazon.com/gp/aw/d/B01C3HAHCS?psc=1 Something like this? What abilities besides error code scanning would this provide? Any hidden menus or ability to change settings that normally would need a dealer for? IE: switching DRL to parking lights? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 Software is what gives you the "dealer" abilities. The OBD adapter should be able to read both HSCAN and MSCAN buses to see everything on a Ford vehicle. Make sure the adapter specifies that it supports MSCAN. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 does the phone app constitute as the "software" needed? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 Yup. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 Ordering mine now Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 My device is usually dedicated to OBD logging, so I don't really care whether I use BT or Wifi. If you use your primary device as your OBD logger, then you probably cannot use more than 1 Bluetooth connection at a time, and thus no other streaming activity. With wifi, you can set the IP address to static for the adapter, and still have cellular connection, from what I have heard. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 I'm not really sure what I'll use it for yet, besides to see what exactly I can do with it. I've never had a device that connects and can look at car in detail. I'll update with what I find useful when I get it 1 Quote Link to comment Share on other sites More sharing options...
junehhan Posted August 18, 2016 Author Report Share Posted August 18, 2016 Data logging would be what I want to do. It would be nice to be able to continuously record rpm, line pressure, boost, a/f ratio, spark advance, and so on to get a picture of what the car is doing at any given time. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 Torque Pro should work fine for that. Forscan Lite is more comprehensive, has more frequent polling if Torque Pro is not enough. As far as support for 2015/16 MYs, you will have to check it out. I do not know offhand if the database has been updated to include them. Quote Link to comment Share on other sites More sharing options...
CARR142 Posted August 18, 2016 Report Share Posted August 18, 2016 Goliath Industry Wireless OBD2 Car Code Reader Scan Tool - Connects Via WiFi With Any IOS, Android & Windows Device - Features A 3000 Code Database - Suitable For Most Cars & Trucks In The USA. eBay price $24.41 + free shipping. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2016 Report Share Posted August 18, 2016 Do you have one of these, CARR142, for how long, and what all do you monitor with it? TIA. Quote Link to comment Share on other sites More sharing options...
CARR142 Posted August 18, 2016 Report Share Posted August 18, 2016 WW, just ordered one, will update asap. 1 Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 18, 2016 Report Share Posted August 18, 2016 Carr I got the same one on Amazon (posted link a few posts up) for $18.99 free Prime shipping Quote Link to comment Share on other sites More sharing options...
junehhan Posted August 19, 2016 Author Report Share Posted August 19, 2016 https://www.scantool.net/scan-tools/smart-phone/obdlink-mx-wi-fi-scan-tool/ What do you guys think about this one for $159 with the Ford program? I know it is pricey but this one appears to be able to do a lot more than most of the other ones. I have used the MSD Dash Hawk which did a lot of stuff, but it will not support any newer Fords. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 19, 2016 Report Share Posted August 19, 2016 I'd probably try a cheap one first before going for one 8x as expensive Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 19, 2016 Report Share Posted August 19, 2016 I would get their bluetooth MX instead. The Wifi unit is, shall we say, "less than reliable". https://www.scantool.net/scan-tools/smart-phone/obdlink-mx-wi-fi-scan-tool/ What do you guys think about this one for $159 with the Ford program? I know it is pricey but this one appears to be able to do a lot more than most of the other ones. I have used the MSD Dash Hawk which did a lot of stuff, but it will not support any newer Fords. Quote Link to comment Share on other sites More sharing options...
junehhan Posted August 19, 2016 Author Report Share Posted August 19, 2016 I would have thought that the wifi would be more reliable than Bluetooth. BT has always been problematic for me with other devices although my Windows phone has been my first instance of not having trouble. I was hoping you guys might have tried this unit as it appears to be the one that will do all I need. Personally, I prefer wires as I am old school. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 19, 2016 Report Share Posted August 19, 2016 I would go wired too if I could. That will always provide the fastest and most stable connection. It's not the technology in question, it's the device. Too many dropouts with the wifi. No dropouts with the Bluetooth, it's just better engineered IMHO. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 20, 2016 Report Share Posted August 20, 2016 So I got my device today, plugged it in and it works with the forscan lite app. But I'm not able to change anything literally can just look at all the options?? The only thing I can change is something called "precision decimal digits"? I changed it on a few things and it didn't do anything. First time using one of these really have no clue what I'm doing nor did I have a ton of time today unfortunately Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 21, 2016 Report Share Posted August 21, 2016 Two possibilities: a) Forscan for Windows has the full capabilities to make changes compared to the Lite versions, and/or they simply have not installed these administrative features yet for the 2015-16 MY. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 22, 2016 Report Share Posted August 22, 2016 Well I tried to mod my device to add MS-Can ability and it appears to be broken lol. When I flipped the switch I put in the car shut off and threw a wrench. I cleared the code in HS mode, but it kept doing it. So I need to find a new tool. Are there any ms/hs can devices for under $50? If anyone could send a link to one. Everything I found is mod your own(which I tried) or in some country I'm not comfortable lurchasing from. Aka UK(customs would kill the deal) and some place I've never heard of that screams scam. I definitely had more options via computer version. Quote Link to comment Share on other sites More sharing options...
