VisionPilot Posted August 16, 2016 Report Share Posted August 16, 2016 (edited) Has anyone experienced a 2-3 second rattle when starting the 2.7liter EB engine after it's been sitting? This started happening at about the 500 mile mark on a 10 day old 2016 (July '16 build) MKX.... I'll see if I can post the link to the video. Edited August 16, 2016 by VisionPilot 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 16, 2016 Report Share Posted August 16, 2016 I was about to refer you to the recent topic on the MKX forum but then I realized you posted both of them. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 16, 2016 Report Share Posted August 16, 2016 (edited) Pretty normal for an Ecoboost engine as oil pressure builds. There is speculation that it is due to the timing chain, and that will in due time turn to timing chain slap and constant rattling. More true on the F150 than in the transverse engined crowd. One solution is to always use the Motorcraft oil filter, it really does allow oil pressure to build quickly. Another is to use a quality full synthetic oil, instead of the minimum spec in the owner's manual. EDIT: I have not heard of an HPFP (high pressure fuel pump, sits atop the engine) failing this early, but it's worth checking that a) the sound is not coming from there, and B] the insulating cover is present. Check the oil level while you are at it. BTW, it's normal for these engines to sound like diesels, as much of the technology is the same. Edited August 16, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Beezz Posted August 16, 2016 Report Share Posted August 16, 2016 (edited) Run to the dealer, that severe of a start up rattle should not be 'normal'. The worst I've heard is a bicycle chain sounding noise when I left it outside during a winter storm. When you say sitting, do you mean a few days, or a few weeks? Edited August 16, 2016 by Beezz Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted August 17, 2016 Author Report Share Posted August 17, 2016 (edited) Run to the dealer, that severe of a start up rattle should not be 'normal'. The worst I've heard is a bicycle chain sounding noise when I left it outside during a winter storm. When you say sitting, do you mean a few days, or a few weeks? one to two hours.... if I restart within an hour, it won't do it.....closer to two hours, and certainly over two hours, massive chain slap from the passenger side of the engine. Edited August 17, 2016 by VisionPilot Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 17, 2016 Report Share Posted August 17, 2016 That definitely merits a dealer visit, like Beezz pointed out. Quote Link to comment Share on other sites More sharing options...
Beezz Posted August 17, 2016 Report Share Posted August 17, 2016 (edited) one to two hours.... if I restart within an hour, it won't do it.....closer to two hours, and certainly over two hours, massive chain slap from the passenger side of the engine. Let the dealer know you might have a loose timing chain Which is just surprising considering how new your engine is. The timing of the issue makes sense as these engines hold oil for a while after shutdown. heres what mine sounds like after sitting for 2 days (17K km): https://drive.google.com/file/d/0B3KiK2mnNJqFcXJXV2llaG1jSmc/view?pref=2&pli=1slight diesel-ish clatter but normal as WWWPerfA_ZN0W said Edited August 17, 2016 by Beezz 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 17, 2016 Report Share Posted August 17, 2016 Quote Link to comment Share on other sites More sharing options...
djrjr Posted August 20, 2016 Report Share Posted August 20, 2016 My God that sounds horrid! I've had 2 2.7 V6's and neither has done that noise at all. Run back to the dealer STAT 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted August 22, 2016 Author Report Share Posted August 22, 2016 (edited) My God that sounds horrid! I've had 2 2.7 V6's and neither has done that noise at all. Run back to the dealer STAT I've been waiting a week for my service appointment. Supposed to drop the car off this evening. From everything I've read, and advice from a professional mechanic friend, it's identical to the VTC phaser failures on the 3.5 Ecoboost, addressed in TSB 16-0027. They wanted to have it overnight so that they could cold start it in the morning, but that won't be necessary. It does it after sitting for only 20-30 minutes! A hot start within 5-10 minutes won't produce the metal/metal rattle. Edited August 22, 2016 by VisionPilot Quote Link to comment Share on other sites More sharing options...
cds71 Posted August 22, 2016 Report Share Posted August 22, 2016 That sounds pretty nasty(Id swear that sounds like a diesel VW)......ive had two 2015 edge sports, and neither had that kind of start up. That definitely screams dealer visit. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 22, 2016 Report Share Posted August 22, 2016 I hope they find the cause, explain it to you, and fix it ASAP! 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted August 31, 2016 Author Report Share Posted August 31, 2016 (edited) I hope they find the cause, explain it to you, and fix it ASAP! It's been 9 days since I dropped the car off at the dealer. It has endured multiple thunderstorms with some hail. They have done absolutely nothing on the car other than confirm the noise. They opened an incident with Lincoln last Tuesday the 23rd, and Lincoln Tech subsequently gave them a test to perform. That test has not been performed, and the car was never brought back inside to a service bay. Instead, they have had at least one, if not more vehicles come in after mine, that they have been working on. I am beyond pissed off. On top of that, when I went to check on it last Friday, it was left unlocked with the keyfob inside in their back lot. I plan to go retrieve the car today, without warning.... Edited August 31, 2016 by VisionPilot Quote Link to comment Share on other sites More sharing options...
akirby Posted August 31, 2016 Report Share Posted August 31, 2016 That's ridiculous. Hope you have another dealer to use. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 31, 2016 Report Share Posted August 31, 2016 Is this a Ford/Lincoln dealer, or a Lincoln-only dealer? Anyways, what did the service mgr have to say about this? 1 Quote Link to comment Share on other sites More sharing options...
Beezz Posted August 31, 2016 Report Share Posted August 31, 2016 Find the service manager and drag them with you to your car, if it is unlocked today, I suggest you do this as you drive off http://www.reactiongifs.com/r/cnvrtble.gif On a more serious note, did they provide you with a free rental for the time being? Was your mkx leased or purchased (I find that people who paid in full don't really get the same attention from the dealer) 3 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted August 31, 2016 Author Report Share Posted August 31, 2016 Is this a Ford/Lincoln dealer, or a Lincoln-only dealer? Anyways, what did the service mgr have to say about this? Multi car complex, but Lincoln only dealer, no Fords. Service manager just says that they have to finish the ones that came in after mine before they have room for it. The issue is that there are multiple open bays, but they service more than one brand. I'm presuming that they only have one tech that does Lincolns, and they have him tied up with cars that came in after mine that have lengthier issues to fix. 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted August 31, 2016 Author Report Share Posted August 31, 2016 (edited) Find the service manager and drag them with you to your car, if it is unlocked today, I suggest you do this as you drive off http://www.reactiongifs.com/r/cnvrtble.gif On a more serious note, did they provide you with a free rental for the time being? Was your mkx leased or purchased (I find that people who paid in full don't really get the same attention from the dealer) It was purchased through Lincoln's finance. Yes, I did get a free rental. That took an extra week to arrange, so in the interim, I quit driving my car anywhere. So, it's really been 2 and a half weeks that I've been without the use of a car that I bought 4 weeks ago. Edited August 31, 2016 by VisionPilot Quote Link to comment Share on other sites More sharing options...
junehhan Posted September 1, 2016 Report Share Posted September 1, 2016 Keep us updated. That sounds scary. Stories like yours terrify me as my dealer is so amazing and I will be moving next spring. Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 1, 2016 Author Report Share Posted September 1, 2016 (edited) I made an appt with another dealer (albeit 10 days out), and drove up to the original dealer on Wednesday, shortly before noon, to pick up my car. I parked where I wouldn't be noticed by the service dept, and walked around the side of the building, around back, and to the other side where my car was parked. Snapped a photo showing the FOB was still in the same place, in the cup holder. Took a pic from the front to show it hadn't budged, and as I was looking at the hood for hail damage, the tech came out and opened the door to get in. Coincidence? Dunno, but I was only at my car a few seconds. I let him pull it into the service bay, and then walked over and spoke to the service writer I had been dealing with. I did not yell, or get angry. I was very calm, but matter of fact. The SW assured me that if I let them keep it, it would not leave the service bay until it was fixed, but that he couldn't blame me if I wanted to take it. I left it there for them to work on. I didn't even bother asking for an estimate as to how long it would take, as they will have to do whatever testing Lincoln prescribes to arrive at a diagnosis. I do know that once they commit to it being the camshaft timing phaser, that is about a 9 hour book job. Edited September 1, 2016 by VisionPilot 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 1, 2016 Report Share Posted September 1, 2016 I hope you don't have any hail damage on your MKX to top off the load of c*** you've been fed so far. 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 1, 2016 Author Report Share Posted September 1, 2016 I hope you don't have any hail damage on your MKX to top off the load of c*** you've been fed so far. Thanks, I hope it doesn't have any damage either. I wasn't able to get a good look, as it still had water on it from all the rains, and the tech walked past me and jumped in which startled me a little. Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 3, 2016 Author Report Share Posted September 3, 2016 And, another new turn of events. I opened a ticket with Lincoln corp on Wednesday. The case manager called me back Friday asking if I was happy with my car. I said.. what? He said he called the dealer, and that the dealer told them I had picked it up. I told him they lied to you. My car is sitting outside their service bay, waiting for parts that aren't supposed to arrive until next week some time... Now what do I do? They straight up lied to Lincoln corp, telling them they fixed my car and I picked it up, which is absolutely not true. Oh, and the Lincoln corp guy did provide them my VIN, so there was no confusion. 1 Quote Link to comment Share on other sites More sharing options...
VisionPilot Posted September 3, 2016 Author Report Share Posted September 3, 2016 (edited) However, the case manager did call the dealer back, and they admitted that they were wrong. They expect the parts any time. At this point, they are telling me they will have it ready next week. I won't hold my breath, it's been one lie after another, as they keep pushing my service back. At this point, I have put more miles on their loaner than the total mileage on my "new" car! Edited September 3, 2016 by VisionPilot 1 Quote Link to comment Share on other sites More sharing options...
junehhan Posted September 3, 2016 Report Share Posted September 3, 2016 I think you need to evaluate your relationship with this dealer. If you cannot trust a bunch of scum like this, how can you trust they fixed it right or did not screw something else up? 2 Quote Link to comment Share on other sites More sharing options...
