BRR-241 and BRRF-101 Brake Rotors
Both are front rotors, same diameter (12.6"), but the BRRF seems to be an "OEM" design and has a grayish coating on it. The other is "retail". Not sure there's any perceptible difference otherwise. The BRRF might resist rust better on the non-braking surfaces?
On the ford website it lists the dimensions as different
The Ford Parts site should be definitive, so I would go with what they spec. Ford specs AWD front rotors at 13", but actual OD is 12.6". FWD front rotors are spec'd at 11.89", but are actually 11.65". This, based on the FordPartsGiant.com site:
http://www.fordpartsgiant.com/parts-list/2008-ford-edge/front-brake-discs-and-calipers.html
7T4Z-1125-A
Rotor Assy
Actual O.D. Is 12.60”, Warranty Eligible
Fit Note: Brake Discs 17"
Callout Name: 1125
2 $108.30 $73.43
7T4Z-1125-B
Rotor Assy
Actual O.D. Is 11.65”, Warranty Eligible
Fit Note: Brake Discs 16"
Callout Name: 1125
Replaced by: 7U2Z-1V125-DC
2 $74.97 $50.83
7U2Z-1V125-DC
Rotor Assy
Ford Retail Spec, Actual O.D. Is 11.65”
Callout Name: 1125
2 $74.97 $50.83
7U2Z-1V125-ED
Rotor Assy
Ford Retail Spec, Actual O.D. Is 12.60”
Callout Name: 1125
2 $83.30 $56.48
