What does a P0016 have to do with water pump failure? Video
macbwt
  • 4 months later...
Coolant sump? You mean the degas bottle? Good question, but I believe not. The computer definitely makes its' decisions based on cylinder head temperature, and if a warning does pop up, immediately stop off in a safe location and do not attempt to restart the engine. Tow to your nearest dealer.
Yes, coolant pump failure should be covered by the standard powertrain warranty.
http://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2017-Ford-Car-Light-Truck-Warranty-version-2_frdwa_EN-US_05_2016.pdf
Your vehicle’s Powertrain components are covered for five years or 60,000 miles, whichever occurs first. The extended coverage applies to the Engine: all internal lubricated parts, cylinder block, cylinder heads, electrical fuel pump, powertrain control module, engine mounts, flywheel, injection pump, manifold (exhaust and intake), manifold bolts, oil pan, oil pump, seals and gaskets, engine thermostat, engine thermostat housing, timing chain cover, timing chain (gears or belt), turbocharger/supercharger unit, valve covers, water pump;
Thanks again! I actually read the PDF, but did not see PTU mentioned in the trany part. I assumed transfer cases was the same. You know what they say when you "assume"
Maybe I'll think of purchasing a Ford ESP in a couple of years if I decide to keep it for awhile. I do like to change things up, so we'll see what's out at that time.
Thank you
Do the PTU fluid change within 1 year/10K miles, then at least every 3/36. I think that would keep any issues from cropping up. Not sure on capacity exactly though ...
I think yours may have a drain plug, not sure, the Sport definitely does. If you do have your Edge on a lift and can grab some pics of the PTU from different angles, that would answer many a question for owners with Gen 2's with AWD. TIA.
