lpgao Posted August 7, 2016 Report Share Posted August 7, 2016 1, After reading posting here I got fuse panle cover and see a set 5 digit numbers but I am not sure if they are the factory set 5 digit code? 2, each button on key pad has two numbers on them so if I have code 1,2,.....how can I enter those two numbers? Press first button twice? Quote Link to comment Share on other sites More sharing options...
akirby Posted August 8, 2016 Report Share Posted August 8, 2016 Yes. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 8, 2016 Report Share Posted August 8, 2016 (edited) Yes those is the factory code. If your first number is EITHER a 1 or a 2, press the 1/2 button. If the second is either a 3 or a 4, press the 3/4 button. Etc. A code of 164 is the same button pressed as 253. (I used three digits instead of five for simplicity). Edited August 8, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2016 Author Report Share Posted August 8, 2016 Yes those is the factory code. If your first number is EITHER a 1 or a 2, press the 1/2 button. If the second is either a 3 or a 4, press the 3/4 button. Etc. A code of 164 is the same button pressed as 253. (I used three digits instead of five for simplicity). Thanks for you guys quick replies. But if the code is 3,4 or 2,1 how should I enter those codes for example? Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 8, 2016 Report Share Posted August 8, 2016 (edited) It does not matter. For sake of simplicity. Think of 1&2, 3&4, 5&6, 7&8, 9&0 as the same number. If your code is 12345. You would press 1&2 twice, 3&4 twice and then 5&6. The exact same pattern as if the code was 22445. I'm not sure there is any other way anyone is going to be able to explain it. Pretty straight forward concept. Each set of numbers, counts as one button press regardless of which number you are hitting. You don't need to try and touch only the number you want just hit the entire button If this doesn't make sense I'd suggest stopping by the dealer and having someone show you in person. Edited August 8, 2016 by Tjm623 Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2016 Author Report Share Posted August 8, 2016 It does not matter. For sake of simplicity. Think of 1&2, 3&4, 5&6, 7&8, 9&0 as the same number. If your code is 12345. You would press 1&2 twice, 3&4 twice and then 5&6. The exact same pattern as if the code was 22445. I'm not sure there is any other way anyone is going to be able to explain it. Pretty straight forward concept. Each set of numbers, counts as one button press regardless of which number you are hitting. You don't need to try and touch only the number you want just hit the entire button If this doesn't make sense I'd suggest stopping by the dealer and having someone show you in person. Thanks lot for your reply. If the numbers I see on cover are indeed the keypad codes how can I verify them? Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 8, 2016 Report Share Posted August 8, 2016 Enter it on the keypad... Do your doors unlock? If so then it works. Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2016 Author Report Share Posted August 8, 2016 Enter it on the keypad... Do your doors unlock? If so then it works. Thanks for your kind reply. I tried the numbers I got from fuse panel cover and nothing happen. I also dont think the code will have 2,1 or 3,4 combination because press same buttons twice not making any sense. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 8, 2016 Report Share Posted August 8, 2016 Go to the dealer and ask. From the sound of it I am not sure you understand how the keypad works Quote Link to comment Share on other sites More sharing options...
akirby Posted August 8, 2016 Report Share Posted August 8, 2016 Thanks for your kind reply. I tried the numbers I got from fuse panel cover and nothing happen. I also dont think the code will have 2,1 or 3,4 combination because press same buttons twice not making any sense. There are only 5 buttons but instead of only using numbers 1-5 they decided to allow you to use all 10 digits (0-9) so you can create codes that are easy to remember like birthdays or other numbers. It doesn't matter if you're pressing the same button twice in a row, or 5 times in a row. Even with only 5 nu,bears you could have a code of 11111. In this case 11111, 22222 and 12121 all equal 5 presses of the 1/2 button. Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2016 Author Report Share Posted August 8, 2016 There are only 5 buttons but instead of only using numbers 1-5 they decided to allow you to use all 10 digits (0-9) so you can create codes that are easy to remember like birthdays or other numbers. It doesn't matter if you're pressing the same button twice in a row, or 5 times in a row. Even with only 5 nu,bears you could have a code of 11111. In this case 11111, 22222 and 12121 all equal 5 presses of the 1/2 button. Thanks again for guys replies. But the numbers I got from fuse panel not working for my door lock so what I can do? Quote Link to comment Share on other sites More sharing options...
akirby Posted August 8, 2016 Report Share Posted August 8, 2016 If those don't work you'll have to take it to the dealer. Quote Link to comment Share on other sites More sharing options...
Waldo Posted August 8, 2016 Report Share Posted August 8, 2016 Did you check in the glovebox for the card? Every Ford with a keypad comes with a credit-card sized card that has the original code on it. Should be in the package with the Owner's guide if you still have that. Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2016 Author Report Share Posted August 8, 2016 Did you check in the glovebox for the card? Every Ford with a keypad comes with a credit-card sized card that has the original code on it. Should be in the package with the Owner's guide if you still have that. Many thanks for your information. I did search glove box and nothing. I bought used one in 2013 and I dont think I can find it. I may go dealer to seek help. Quote Link to comment Share on other sites More sharing options...
candurin Posted August 8, 2016 Report Share Posted August 8, 2016 I admittedly don't really use my keypad, by try using the 6 OEM digit code and then the 7/8 key and see if that unlocks the doors. Then press the 3/4 and 5/6 key simultaneously to lock them. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 9, 2016 Report Share Posted August 9, 2016 I admittedly don't really use my keypad, by try using the 6 OEM digit code and then the 7/8 key and see if that unlocks the doors. Then press the 3/4 and 5/6 key simultaneously to lock them. You have those combos completely backwards lol. Your unlock code and then a press of 3/4 opens all the doors. And holding 7/8 and 9/0 together locks them all. Also, doesn't work on SUVs but 5/6 on a sedan would pop the trunk. Quote Link to comment Share on other sites More sharing options...
candurin Posted August 9, 2016 Report Share Posted August 9, 2016 Oops. Well, anything i can do to make your job more difficult, please do not hesitate to ask! Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 9, 2016 Report Share Posted August 9, 2016 Oops. Well, anything i can do to make your job more difficult, please do not hesitate to ask! LOL, at least you have a sense of humor about it! Quote Link to comment Share on other sites More sharing options...
