fishx65 Posted August 7, 2016 Report Share Posted August 7, 2016 (edited) Getting some creaking up front while braking and turning to the right. This is a 2011 SEL with 70,000 miles. Haven't crawled under there yet but I'm guessing sway bar links or strut mount noise. Anyone have the same thing going on???? Edited August 7, 2016 by fishx65 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 8, 2016 Report Share Posted August 8, 2016 broken sway bar links will make for of a metallic clank. Strut bearing mounts are more a dull clunking sound up higher. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 8, 2016 Author Report Share Posted August 8, 2016 Thanks Mac, I'm gonna take a look this week. Might try spraying the crap out of the sway bar links with penetrating lube just to see if the sound goes away. Just watched your sway bar link replacement video and decided that you need to keep a nice pair of mechanics gloves handy. Did you end up removing the zerk fittings because of contact issues or did you just leave them in there??? Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 8, 2016 Report Share Posted August 8, 2016 They were tightened some more and have about 1/4 inch clearance and to date have not touched the drive shaft. So a win! I have been working on the glove issue, I like to have some feel for things when I work, but yeah gloves are needed. Looking some thicker Nitrile gloves the thinner ones do not hold up. Maybe 7mm or 9mm not sure. I will test them out and let you know in future videos. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 8, 2016 Report Share Posted August 8, 2016 Most likely culprits are strut mount, control arm bushing, and swaybar link. All bushings should be checked thoroughly first. If you find faulty components on one side, do both sides, because the other side won't be far behind. Ā A caliper dust boot is an unusual suspect, but worth checking, if the creak is very "small". Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 8, 2016 Author Report Share Posted August 8, 2016 (edited) Znow, the caliper dust boot comment gets my attention because I only hear the creaking when braking from a slow role. I assume you're referring to the caliper piston dust boot? Mine were pretty dirty when I did the brakes a few months ago but, after cleaning them up, they did compress without distorting when I turned the piston back in. Also, I would think that bad sway bar links would make a lot of noise when going over speed bumps at slow speeds at various angles. I'm not getting the typical noises I've gotten from previous vehicles with bad sway bar links. This noise sounds like a door closing very slowly that's in desperate need of grease. I started noticing it about a year ago and it's gotten worse lately. Edited August 8, 2016 by fishx65 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 8, 2016 Report Share Posted August 8, 2016 Sway bar bushings!!! Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 8, 2016 Report Share Posted August 8, 2016 Fishx65. Just kidding with ya but you sure it is not the ole bones creaking? LOL Znow, the caliper dust boot comment gets my attention because I only hear the creaking when braking from a slow role. I assume you're referring to the caliper piston dust boot? Mine were pretty dirty when I did the brakes a few months ago but, after cleaning them up, they did compress without distorting when I turned the piston back in. Also, I would think that bad sway bar links would make a lot of noise when going over speed bumps at slow speeds at various angles. I'm not getting the typical noises I've gotten from previous vehicles with bad sway bar links. This noise sounds like a door closing very slowly that's in desperate need of grease. I started noticing it about a year ago and it's gotten worse lately. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 8, 2016 Report Share Posted August 8, 2016 Yup, the caliper piston dust boots. Mind you, I have never heard it causing issues on any of my vehicles, so no personal experience, but I have read about it a couple times while surfing the net. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 9, 2016 Author Report Share Posted August 9, 2016 Fishx65. Just kidding with ya but you sure it is not the ole bones creaking? LOL I'm cool, only one knee, one shoulder and the lower back creak but it's only in the mornings. 2 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 22, 2016 Author Report Share Posted August 22, 2016 (edited) Cheaped out and ordered a set of links on ebay for 20 bones. They look a little beefier then most and have grease fittings so maybe they're decent. Ā http://www.ebay.com/itm/221777391501?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Edited August 22, 2016 by fishx65 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 22, 2016 Report Share Posted August 22, 2016 Well, at least they will help figure out the source of the problem, even if they snap in 3 months or so LOL! J/K, looking forward to updates! 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 30, 2016 Author Report Share Posted August 30, 2016 (edited) Got the $20.00 JPN links in the mail and they look and feel like a quality part. They are very similar in design to the Moogs with the same beefy build. Only had time to install one side so far but it's a pretty easy job if ya have the right tools. My best friend is a Dremel with a cutoff disc!!!!! Edited August 30, 2016 by fishx65 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 30, 2016 Report Share Posted August 30, 2016 Bill only recommends Sawzall LOL. 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted September 5, 2016 Author Report Share Posted September 5, 2016 (edited) Both links installed and she's been quiet so far . I should have ripped open the boots on the old links to see how dry they were but I pitched them. Edited September 5, 2016 by fishx65 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 5, 2016 Report Share Posted September 5, 2016 Sway Bar Links ... SMH. Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 5, 2016 Report Share Posted September 5, 2016 Old bones! LOL 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 7, 2016 Report Share Posted September 7, 2016 Old bones! LOL Oh no, that only affects the rear suspension. 2 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted September 12, 2016 Author Report Share Posted September 12, 2016 Still Creakin. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 12, 2016 Report Share Posted September 12, 2016 I would try lubing the swaybar bushings see if the noise goes away. It will probably return, since proper greasing of the bushings is usually done with them off the vehicle. I am not sure what the material is on these bushings. If rubber, they say not to grease at all. If polyurethane, there is a special grease for that. A synthetic grease like Super Lube might be best. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted September 12, 2016 Author Report Share Posted September 12, 2016 I'm gonna crawl under there in the next couple of days with a grease needle and will be sure to hit the SB bushings if possible. Other option is to strap myself underneath while someone drives me around to locate the noise. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 12, 2016 Report Share Posted September 12, 2016 Oh no, not you too!!! LOL. Just make sure it's someone who loves you that's driving you around Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 12, 2016 Report Share Posted September 12, 2016 If you do that I would like to make as suggestion. Please add my name to your life insurance policy. All kidding aside. You can do the same thing with a gopro camera. 1 Quote Link to comment Share on other sites More sharing options...
