davidceder Posted December 25, 2016 Report Share Posted December 25, 2016 The coffee thing DOES drive me crazy. I just feel if there is a car in the BS and you are serious about making the lane change, a bit more of warning is a good thing. As I said, nice if you had the option to turn it off. Not gonna happen anyway..... Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted April 26, 2020 Report Share Posted April 26, 2020 On 8/5/2016 at 10:38 PM, jmr061 said: I have a 16 Sport. I have successfully added CLIMATE to the right side of instrument cluster. Mine has global window opening from the factory. I added global close to the IPC and enabled it in the door modules and have that working. If you have programming software and hardware that can access the as built data for those let me know and I can help you out (free) for adding that stuff. Jason Expand 2018 Edge Titanium here, already have forscan and cable. Ive been trying to get Global Close added and havent had any success with f150 codes. I'd be happy to try out the climate/instrument cluster change as well. Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 26, 2020 Report Share Posted April 26, 2020 Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted April 26, 2020 Report Share Posted April 26, 2020 On 4/26/2020 at 4:29 AM, soUNTOUCHABLE said: 2018 Edge Titanium here, already have forscan and cable. Ive been trying to get Global Close added and havent had any success with f150 codes. I'd be happy to try out the climate/instrument cluster change as well. Expand Try these values from the Fusion G2 IPC 720-05-01 xxXxx xxxx xxxx xxBx-xxxx-xxx (climate in right cluster) 8xxx-xxxx-xxxx (removes CD/Sirius from right cluster Global Windows Remote Close: 726-17-01 (2014+ MY) xXxX xXxX xXxx (BdyCM) 0101 0101 014A (Enabled - Default) 0000 0000 0045 (Disabled) Global Windows Remote Open: 726-17-02 (2014+ MY) xXxX xXxX xXxx (BdyCM) 0101 0101 014B (Enabled - Default) 0000 0000 0046 (Disabled) 1 Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted April 26, 2020 Report Share Posted April 26, 2020 On 4/26/2020 at 4:29 AM, soUNTOUCHABLE said: 2018 Edge Titanium here, already have forscan and cable. Ive been trying to get Global Close added and havent had any success with f150 codes. I'd be happy to try out the climate/instrument cluster change as well. Expand You'll find a list of FORScan mods I've made to my '16 Ti (including global window open/close) here: https://www.gadgetjq.net/edge/forscan/forscan.html#changes Every one of them works with no ill effects on any other system. Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted May 3, 2020 Report Share Posted May 3, 2020 Thanks guys, I'll be trying that out next time I plug in! I looked at your site gadget, but I didn't see the global close option. I'll have to look again. ONEDGE16 much appreciated! Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted May 3, 2020 Report Share Posted May 3, 2020 On 5/3/2020 at 12:46 AM, soUNTOUCHABLE said: ! I looked at your site gadget, but I didn't see the global close option. I'll have to look again. Expand The very first change (FORScan page): 1. Windows Remote Open/Close After doing these FORScan changes you can press and hold unlock on your key fob for windows to roll down. Press and hold lock button on the fob to roll windows up. Chances are pretty good you can currently roll your windows 'up' with your fob but not down. Give it a try. This is one of those things that may have changed from model to model and year to year. BdyCM (As-Built): 726-17-01 0101 0101 014A 726-17-02 0101 0101 014B 726-30-01 0101 0000 0060 DDM: 740-05-01 Dxxx xx PDM: 741-05-01 Dxxx xx Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted May 4, 2020 Report Share Posted May 4, 2020 @Gadgetjq Can you clarify something for me from your list, plz? I have navigation, and i want to add climate to my right screen. So do i need xx8x in the first 4 digits? or am i misreading the bold section? Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted May 4, 2020 Report Share Posted May 4, 2020 On 5/4/2020 at 4:19 PM, soUNTOUCHABLE said: @Gadgetjq Can you clarify something for me from your list, plz? I have navigation, and i want to add climate to my right screen. So do i need xx8x in the first 4 digits? or am i misreading the bold section? Expand Your default should be D8B8. The other numbers shown are to 'remove' items from the right screen (like Sirius if you don't have a subscription) I don't remember what I had from the factory but climate was missing on my '16. I changed the code to D8B8 and voila! That said, I never use it because I already have climate on the main screen and physical buttons so... Quote Link to comment Share on other sites More sharing options...
soUNTOUCHABLE Posted May 5, 2020 Report Share Posted May 5, 2020 Thanks! I understand now, I'll dry D8B8 next time. I dont NEED climate control on that screen either lol, I just want to check it out really. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
