wlepse Posted November 9, 2016 Author Report Share Posted November 9, 2016 Thanks. Downloaded PDF and bookmarked this page. Hopefully I will never need it. Quote Link to comment Share on other sites More sharing options...
freebird Posted November 10, 2016 Report Share Posted November 10, 2016 On 11/9/2016 at 5:43 PM, wlepse said: Thanks. Downloaded PDF and bookmarked this page. Hopefully I will never need it. ... or if you need it the extended service campaign will apply! Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 10, 2016 Author Report Share Posted November 10, 2016 Not for me since I already had it replaced...I think it is a one and done thing. Just hoping the problem with the booster was a bad batch or something rather than a crap design like the door latches that continually fail. Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 25, 2016 Report Share Posted November 25, 2016 Removing the upper plenum would also provide more room. 1 Quote Link to comment Share on other sites More sharing options...
Alaxgoaly8 Posted May 23, 2018 Report Share Posted May 23, 2018 Does anyone know if Ford made design adjustments to the Brake Booster or are they just putting new boosters in that have the same design failure? Looking to buy a 2013 with 54k miles on it that has had the booster replaced so I would be out of pocket if it went again. Quote Link to comment Share on other sites More sharing options...
EDST777 Posted July 25, 2018 Report Share Posted July 25, 2018 Hello, I have also now news. Now I have whistle when strongly I press the brake pedal, after the long parking. During driving, so far everything is all right. There is also a hissing when pressing the brake pedal. I want to know that it leads to replacement of Power Brake Booster? Whether it is necessary to replace booster vacuum line jointly? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 25, 2018 Report Share Posted July 25, 2018 Does sound like the brake booster is failing. Good idea to replace the vacuum line also, although it might have a few years of life left. Hoses fail with age, and that hose is in a relatively hot location in the engine compartment. 1 Quote Link to comment Share on other sites More sharing options...
EDST777 Posted July 25, 2018 Report Share Posted July 25, 2018 Thanks! I have a problem, I can't load the PDF files placed in subjects why it occurs? Any thoughts. Thanks. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2018 Report Share Posted July 27, 2018 The link is definitely broken. Here you go: Ford Edge Gen1 BRAKE BOOSTER REPLACE.pdfFetching info... 1 Quote Link to comment Share on other sites More sharing options...
EDST777 Posted July 27, 2018 Report Share Posted July 27, 2018 Thanks. Using this document I will compile information, I prepare for replacement of the booster, but I would like to make it as wrote in the next subject without separation of brake lines and the ABS lines but only having removed the front fairing (cowl). Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Krcole Posted February 8, 2020 Report Share Posted February 8, 2020 (edited) For anyone with the sudden sinking pedal. I had the pedal go to the floor with my son on a learner's permit driving. Slipped into intersection and luckily nobody was coming from either way. Repaired under warranty with brake booster replaced. Few months later went over rough railroad crossing and pedal again went to floor with no power brakes. Paid ford dealership another $1200 to repair with new brake master cylinder installed. Three months later hit a patch of snow and antilock activated and same problem, no power brakes. Ford said good news, we've replaced everything so should be no charge this time. Days later call and say it's the abs control module stuck valve, $1200. I called bs and said pull her out and give me the keys. I may have used less civilized words. Watched a lot of youtube stating I should jam on brakes to activate and "unblock" the abs manifold/block/module. Tried and no luck. Finally, read further and someone suggested not only jamming brakes on gravel road in forward to activate abs but also doing in reverse. Tried in reverse and pedal IMEDIATLLY came back to normal. 1 1/2 years later 30k miles later and free youtube fix still going with no problems and $2400 stealership fixes were a waste and never did fix problem or protect my family. After you make ford replace the booster under the extended coverage customer satisfaction program, find a gravel road, drive her up to 25 mph a couple of times and jam the brakes, then do same in reverse (no need to be at 25 here) then send me the ,$2,400. Only kidding. Those sacks of xxx at stealership will try to charge you that much and dont really fix, they just bleed and temporarily mask the problem. Just walk in and tell them Ken says they suck. Edited February 8, 2020 by Krcole 4 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 8, 2020 Report Share Posted February 8, 2020 Good to know Quote Link to comment Share on other sites More sharing options...
2kool Posted September 1, 2020 Report Share Posted September 1, 2020 (edited) 2013 edge, 111,000 miles, pedal slowly going to floor last week . dealer swapped booster today under customer satisfaction program, (free) and tested master cylinder. says problem still exist. wants $1,400.00 to replace some module under the master cylinder/booster area. ?? no fuking way. going to pick it up shortly and will try the dirt road trick. thanks. I did not see this module available on rock auto? anyone know where I can find it and if I can swap if need be? thanks, TOM okay, UPDATE: back from dealer, new booster but charged me $150.00 for brake system diagnostic. and want to replace HCU ..........nope, drove home but took a dirt road and activated ABS @ about 30 mph. pedal and brakes felt completely normal!! did it in reverse also for good measure, but I am back in business, guessing stuck valve!! thank you!!!! Edited September 1, 2020 by 2kool add t ostory Quote Link to comment Share on other sites More sharing options...
wjharriott Posted September 4, 2020 Report Share Posted September 4, 2020 I just replaced the brake booster because all signs pointed to it being bad. very hard pedal and unable to stop almost at all. after replacement it was much better, but still same issues, hard pedal,but stopping much better. Can anyone touch on this, do i need to replace the master cylinder as well ? Could it be a bad Master cylinder? HELP!!! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 4, 2020 Report Share Posted September 4, 2020 Did you see the comment above? Alternatively, do an ABS Bleed service function with Forscan Lite. May need to follow up with a main system bleed if still some issues remaining. 1 Quote Link to comment Share on other sites More sharing options...
2kool Posted September 15, 2020 Report Share Posted September 15, 2020 On 9/1/2020 at 8:19 PM, 2kool said: 2013 edge, 111,000 miles, pedal slowly going to floor last week . dealer swapped booster today under customer satisfaction program, (free) and tested master cylinder. says problem still exist. wants $1,400.00 to replace some module under the master cylinder/booster area. ?? no fuking way. going to pick it up shortly and will try the dirt road trick. thanks. I did not see this module available on rock auto? anyone know where I can find it and if I can swap if need be? thanks, TOM okay, UPDATE: back from dealer, new booster but charged me $150.00 for brake system diagnostic. and want to replace HCU ..........nope, drove home but took a dirt road and activated ABS @ about 30 mph. pedal and brakes felt completely normal!! did it in reverse also for good measure, but I am back in business, guessing stuck valve!! thank you!!!! Expand update: got my $150.00 refunded as brake diag. was not authorized. 2 Quote Link to comment Share on other sites More sharing options...
Victor Gwinn Posted March 10, 2024 Report Share Posted March 10, 2024 I got a recall letter march 8th 2024. I tried to get the dealer to fix it in mid year 2022 and again in earlier in 2023.they told no recall and the parts aren't avail in fords part and no after market. Basically they said you out of luck. Crazy though now, after sitting for 8 months it is no longer hissing and power brakes are working. I bet they won't replace it because the symptoms are not occurring. Quote Link to comment Share on other sites More sharing options...
SpartanEdge22 Posted April 7, 2024 Report Share Posted April 7, 2024 My brakes are soft and pedal goes to the floor after having to slam on my brakes with 2 tires off road so abs activated. Bled the brakes to see if it was air or whatever….no luck….test drove and got the mail on the way back with the recall for the break booster. Symptoms matched so I took it to the dealership. They say booster is fine and it’s my abs control module (DT4Z2C219B). That part is on national back order with no date. Used parts are a gamble and expensive because they sell the combo but I have a useless car so I might have to take the risk. Any ideas? Did not try the reverse trick when I had it. It’s sitting at the dealership who could care less and would love to charge me all the money. Quote Link to comment Share on other sites More sharing options...
