2015 edge oem rim sizes
im trying to find the optional rim sizes that ford provides on this car. from what ive seen, the sel, the se, and the sport all have different rim sizes from 18x8(my default size) up to 20 inch, yet they appear to have the same clearance and suspensions. i am looking at some options to buy ford oem black chrome rims in 19 inch from the fusion and/or explorer but im not sure they will fit or cause any issues with the awd, being this car comes with so many different rim sizes im thinking physically they will fit but not sure if ford changes anything in the ecu from se, to sel, to sport. i hope i explained myself well and hope there is someone here that knows a bit more about this stuff than i do, thanks in advance
Edited by greeneye150
2015 comes in 18-21" sizes. As long as the diameter is good the car will work and awd is fine.
Example: 265/40/21 is the same as 245/50/20. Same as 245/55/19 and 245/60/18. Make sure the brakes clear which should not be too hard as they aren't very fancy. Bolt pattern is 5x108 as mentioned above.
Bigger wheels generally add weight so you actually lose performance in braking, turning, accelerating. Assuming the tires are the same, you can get performance tires but the mpg hit will certainly still be there, it won't be huge but probably big enough to measure.
this is a big factor for me, id be pretty Teed off if i spent all that money and started noticing these performance losses. what im getting from everything posted so far is stay the same wheel size
