Elmopilot Posted July 30, 2016 Report Share Posted July 30, 2016 Should I need two hands to generate the strength to turn the wheel during parking maneuvers? I've never experienced this before. Quote Link to comment Share on other sites More sharing options...
James Costa Posted July 31, 2016 Report Share Posted July 31, 2016 Definitely not normal ... on my 2016 AWD its effortless. I know on the 2016 it is electric power steering instead of hydraulic, not sure about your year. Is it like this every time? What about at speed? You might want to get it checked out. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 31, 2016 Report Share Posted July 31, 2016 Is the steering electric or hydraulic, Elmo? If it's hydraulic (non Ecoboost engines), you should do a drain & fill on the reservoir and see if that helps. I like to take out as much fluid out of the reservoir as possible, fill it back up, turn the steering wheel lock to lock a few times (never holding at lock) to get the air out. Drive around for a few miles. Then repeat the process twice more. That should get the fluid looking nice & new. Use Mercon LV. Ā Also check underneath for any signs of leakage from the power steering lines. Ā If you have the Ecoboost engine, I believe you will have electric steering, in which case the EPAS module or the steering angle sensor may be bad. Quote Link to comment Share on other sites More sharing options...
Elmopilot Posted July 31, 2016 Author Report Share Posted July 31, 2016 James, at speed the steering seems a bit stiff, but not as pronounced as during parking speeds. I cannot comfortably steer at speed with anything less than a one-handed firm grip. My 2012 Explorer is effortless in both parking speeds and driving speeds. Quote Link to comment Share on other sites More sharing options...
Elmopilot Posted July 31, 2016 Author Report Share Posted July 31, 2016 Engine is a non-EcoBoost V6; likely hydraulic steering. Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 31, 2016 Report Share Posted July 31, 2016 The 2011-2014 Edge (V6, not sure of the Eco) have normal hydraulic power assisted steering. It is generally hard/harder than other non-sport cars. The 2011+ Explorer has EPAS (Electrical Power Assisted Steering) & I is much lighter than the 2011-2014 Edge. Quote Link to comment Share on other sites More sharing options...
