2010 Edge intermittent AC problem
Inconsistent cooling. . .
STATS: Low pressure is 36PSI
At times Compressor runs 5 seconds on / off for 15 seconds, & repeats for around 90 -120 seconds. May run perfectly for another 20 minutes, then repeats the same problem.
I'm extremely good at mechanical, and somewhat good at electrical. My intuition tells me a sensor is faulty?
Any input would be helpful
SOLVED - Too much refrigerant in the system. Although well in the green arc on the gauge,& on the high side of center, I would recommend slightly lower than center green. For some reason, Ford Edge requires a very narrow range for refeigerant quantity. The high pressure "shut down" kicks in, until pressure drops, and this cycle repeats.
  • Like 3
  • 7 years later...
