2015. 5 digit security code location
Depends on what year it is. If it's newer read the manual, there is a sequence you must do with both key fobs which involves placing key in center console, pressing start button and then doing same procedure with other key fob.
The code then displays on your dash screen
My Edge is 2011 model and tried your way and found nothing displayed. Can you explain more specific how to do this procedure?
