Transmission Fluid thermal bypass valve failure
macbwt
Transmission Fluid thermal bypass valve failure. Have a few quires. Does anyone have information on the temperature at which the bypass valve opens?
Anyone else have a documented failure? I have found some information. Not much on net and nothing on YT. I am getting prepared to replace this part as my transmission is overheating gradually during long 150+ drives.
No warning lights at is does not reach the point of overheating to send a Wrench light or CEL
Any information on this would be appreciated or links to additional information.
Don't have a DEFINITE answer to the opening temp, but the FSM does say this:
  Quote
When the transmission fluid is at or above normal operating temperature, the transmission fluid thermal bypass valve opens allowing transmission fluid to travel from the transaxle through the transmission fluid cooler then back to the transaxle.
And the manual specs NOT as 180-200F
  Quote
The transmission fluid should be checked at normal operating temperature 180°F-200°F (82°C-93°C) on a level surface.
So I'd say around 180F.
I read somewhere that the fluid by pass opens at possibly 85 degrees F for reason to allow the quickest heat up time for the overdrive in the transmission. The interesting thing is the trans temp as you posted says 180-200 degrees F So based on that I am not completely out of spec but still running at this time after fluid replacement about 200 consistent at highway speed over long drives. In town however today it start to go up to 201 and 202 but would also drop. So maybe my trans is not running too hot with the new fluid, but it was running 210 on the highway at speed and that is over the spec.
Still in the maybe category on if a new bypass valve will be the cure to keep the temps down. I may just pull the trigger and replace it anyway.
Mac, are both your Edges the same with regards to the towing package? (both have it/don't have it). I think this might be a major difference that could affect temp difference between both.
Also, as per the Owners Manual, it is normal for the trans tempreture to increase after long drives:
  Quote
Automatic transmission fluid expands when warmed. To obtain an
accurate fluid check, drive the vehicle until it is warmed up
(approximately 20 miles [30 km]). If your vehicle has been
operated for an extended period at high speeds, in city traffic
during hot weather or pulling a trailer, the vehicle should be
turned off until normal operating temperatures are reached to
allow the fluid to cool before checking. Depending on vehicle use,
cooling times could take up to 30 minutes or longer.
I am waiting for transmission fluid testing results. After the test is received I will evaluate my next step. In the mean time I will be cleaning the condenser to ensure it is not dirty. I pick up the new bypass valve today and will wait for the test results. I still may replace it. The replacement may end up one of two ways. Either it helps reduce the temps or it does nothing to change it. 45 bucks to find out.
Still trying to figure out why to exactly the same Edges have two different temps on the transmission. Curious.
