ben senise Posted July 8, 2016 Report Share Posted July 8, 2016 i've had my 2016 titanium for a little over a month now and have come across a small problem. when i press the "easyfold" button on the left rear quarter panel in the storage area to fold the seats, the left (driver) side rear seat does not go down on its own. right side works fine and i can manually fold the seat from the rear driver side door. it just doesn't work with the button. just wondering if anyone else has had a similar issue and if so, did you find an easy solution. my dealer offers a complimentary 90 day check-up so i will raise the issue with them then but just seeing if there's an easy fix i can do on my own. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted July 8, 2016 Report Share Posted July 8, 2016 I also noticed this problem with my 16. It sounds to me like the same exact situation - I can manually fold the driver side, but it will not operate with the switch - right side works fine. I plan to have it corrected at the first oil change appointment. Quote Link to comment Share on other sites More sharing options...
PaulSchott Posted July 8, 2016 Report Share Posted July 8, 2016 Can you hear the motor trying to work or is it just dead? Could be switch, motor, wiring. If it's under warrantee let them worry about it You could pull the plug on the motor and test for power when the switch is used. also test for power on each side of the switch to see if power is getting through the switch. your getting power to the switch if the other side works. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted July 8, 2016 Report Share Posted July 8, 2016 Can you hear the motor trying to work or is it just dead? Could be switch, motor, wiring. If it's under warrantee let them worry about it You could pull the plug on the motor and test for power when the switch is used. also test for power on each side of the switch to see if power is getting through the switch. your getting power to the switch if the other side works. In my case - I can hear the motor trying to actuate the seat - but it isn't moving the left side. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 8, 2016 Report Share Posted July 8, 2016 (edited) Seat moves under spring pressure. Binding or broken spring. Is the seat reclinded? Edited July 8, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
ben senise Posted July 9, 2016 Author Report Share Posted July 9, 2016 Can you hear the motor trying to work or is it just dead? Could be switch, motor, wiring. If it's under warrantee let them worry about it You could pull the plug on the motor and test for power when the switch is used. also test for power on each side of the switch to see if power is getting through the switch. your getting power to the switch if the other side works. i can hear the motor and i can hear the latch disengage. the seat moves a tiny bit but just doesn't pop forward. my '09 worked perfectly Seat moves under spring pressure. Binding or broken spring. Is the seat reclinded? seat is not reclined. it appears as though the spring is just not strong enough to pop it forward when the latch disengages. i'll let the dealer take care of it, if they can, but i was just wondering if anyone else had this problem. interesting that TourGuide has the identical problem. Quote Link to comment Share on other sites More sharing options...
James Costa Posted July 9, 2016 Report Share Posted July 9, 2016 I also experienced the exact same problem the other day on my 2016 SEL, havent looked into it yet. the right side works fine, but go to drop the left/middle seat, and nothing, but you do hear the motor noise trying to work. same as tourguide and ben senise. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 9, 2016 Report Share Posted July 9, 2016 May just need to work the seat back and forth a few times to loosen it up. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted July 9, 2016 Report Share Posted July 9, 2016 Seat moves under spring pressure. Binding or broken spring. Is the seat reclinded? I have verified that the seat is not reclined. This will be my first verified warranty claim. Quote Link to comment Share on other sites More sharing options...
davidceder Posted July 9, 2016 Report Share Posted July 9, 2016 2016 Sport here, same exact problem. Figured it was just tight because it is new. Doesn't bother me very much. No big deal for me except it doesn't work as advertised. I will hang out and what you guys come up with. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 10, 2016 Report Share Posted July 10, 2016 Just curious. Does the seat fold manually after its released? Quote Link to comment Share on other sites More sharing options...
WingNut Posted July 11, 2016 Report Share Posted July 11, 2016 I have used this feature on my '15 many times with no issue. Have the dealer check it out. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 11, 2016 Report Share Posted July 11, 2016 I would try working it back and forth a few times to see of it loosens up before taking it to the dealer. Quote Link to comment Share on other sites More sharing options...
Michaelv50211 Posted July 31, 2016 Report Share Posted July 31, 2016 Same problem on my 16. If you manually do it a few times and try it will work. It's almost like the back seat bottom is so thick it stops it from folding. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted July 31, 2016 Report Share Posted July 31, 2016 I would try working it back and forth a few times to see of it loosens up before taking it to the dealer. I did try this - I worked it a few times and now it is folding - although the folding isn't prefect, it does work. I certainly wouldn't call these seats 'fold flat' by any means. Quote Link to comment Share on other sites More sharing options...
ben senise Posted July 31, 2016 Author Report Share Posted July 31, 2016 I would try working it back and forth a few times to see of it loosens up before taking it to the dealer. i did this and it seems to have improved the situation. i haven't tested it that many times since i rarely fold the rear seats down. Quote Link to comment Share on other sites More sharing options...
James Hopson Posted March 13, 2017 Report Share Posted March 13, 2017 We asked at the dealer about this very thing and was told Ford designed it like that and it was functioning correctly. Seems wrong to me but we took but he said they tested a few other Edge's on the lot and they all do the same thing (mine was a new 2016) Quote Link to comment Share on other sites More sharing options...
gary255 Posted March 14, 2017 Report Share Posted March 14, 2017 I don't understand the logic of Ford saying that it's designed to function this way but mine does the same thing. Quote Link to comment Share on other sites More sharing options...
gary255 Posted March 14, 2017 Report Share Posted March 14, 2017 I looked at a lot of youtube videos with the dealer walkaround showings of the 2016 Edges and every time they would demo the seat folding feature the same issue would show up. Quote Link to comment Share on other sites More sharing options...
omar302 Posted March 15, 2017 Report Share Posted March 15, 2017 Those having the issue, do you press & release the button or press & hold it? In my MKX (though an older generation) you have to press for a second or so. Quote Link to comment Share on other sites More sharing options...
jmr061 Posted March 15, 2017 Report Share Posted March 15, 2017 There is actually a service bulletin the driver side rear flip down portion. If it doesn't release to a certain angle they will replace some parts in it. 1 Quote Link to comment Share on other sites More sharing options...
ben senise Posted March 15, 2017 Author Report Share Posted March 15, 2017 There is actually a service bulletin the driver side rear flip down portion. If it doesn't release to a certain angle they will replace some parts in it. wow, ford finally recognizes a problem that people are having! does this service bulletin prescribe a remedy or does it simply acknowledge the problem? is there anywhere to see this service bulletin? Quote Link to comment Share on other sites More sharing options...
jmr061 Posted March 15, 2017 Report Share Posted March 15, 2017 (edited) TSB 16-2085 - Effective Dec 2 2016 2015-2016 Edge/2016 MKX - Left Rear Seat Backrest Does Not Fold Down When Using The Second Row Seat Control Switch - Built On Or Before 9-Sep-2016 Edited March 15, 2017 by jmr061 Quote Link to comment Share on other sites More sharing options...
akirby Posted March 15, 2017 Report Share Posted March 15, 2017 does this service bulletin prescribe a remedy or does it simply acknowledge the problem? If it doesn't release to a certain angle they will replace some parts in it. 1 Quote Link to comment Share on other sites More sharing options...
ben senise Posted March 18, 2017 Author Report Share Posted March 18, 2017 Thanks very much jmr061 and akirby. Now I have what is needed to have them do something when I take it in for the next service. Quote Link to comment Share on other sites More sharing options...
