Val Stanis Posted July 7, 2016 Report Share Posted July 7, 2016 I have a Ford Edge 2016 Titanium and by default my DRL is my low beam light. So, all the time my headlight are ON. On some of the Edges I saw that high beam is used for DRL. I'm wondering if this can be changed by myself or I need to go to the dealer to change this? Quote Link to comment Share on other sites More sharing options...
Hermans Posted July 7, 2016 Report Share Posted July 7, 2016 You can turn off DRLs by using the controls on the left side of the steering wheel cpntrols and the left screen. I turned mine off. When I travel in Canada, I'll turn them on. Quote Link to comment Share on other sites More sharing options...
Val Stanis Posted July 8, 2016 Author Report Share Posted July 8, 2016 In Canadian version of Edge, there is no such option. Quote Link to comment Share on other sites More sharing options...
cjh Posted July 8, 2016 Report Share Posted July 8, 2016 Edges with HIDs = both low and high beams come from the projector housing = DRL is in the place where the high beam normally is. Edges without HIDs = DRL and low beam come from the same bulb = high beam is separate. No you cannot change this unless you swap your headlights with a vehicle that has HIDs. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 8, 2016 Report Share Posted July 8, 2016 In Canadian version of Edge, there is no such option. Can be turned back on by a dealer. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted August 7, 2016 Report Share Posted August 7, 2016 If you shut this feature off via menu will the LED signature lamps still be on? I wish they used the turn signals like my f150 did...I feel like the using the actual low beam has premature burnout written all over it. If you do a HID kit for the halgon setup, what happens to DRL? Does it try to use them at lower wattage? I can't imagine that's good for those bulbs. Or are u forced to shut them off via options in order to use said kit 1 Quote Link to comment Share on other sites More sharing options...
