Dfirth5963 Posted July 4, 2016 Report Share Posted July 4, 2016 What could be causing stuttering between 40 & 50 mph? Stops when I disable O/D, but downshifting is unusual with jumps to 3,000 rpm. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 4, 2016 Report Share Posted July 4, 2016 How many miles on your Edge? Without O/D engaged, it is normal for engine RPMs to be much higher. 1 Quote Link to comment Share on other sites More sharing options...
Brian K Posted July 8, 2016 Report Share Posted July 8, 2016 (edited) Check to see if the transmission oil is the right level. Usually if it is low, you will feel a jerky start and the engine over revving before catching and off you go. I've also found that my drive system feels smoother after changing my PTU fluid. It just seems to have a smoother feel. Edited July 8, 2016 by Brian K 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 10, 2016 Report Share Posted July 10, 2016 Year? Miles? Sound like this is a 1st Gen Edge. Quote Link to comment Share on other sites More sharing options...
