2013 edge side object detection wiring diagram
Lance Moss
Hello.
I appear to have an issue with the detection light in the driver side mirror. I get an error stating it's not connected basically.
I tested the mirror assembly itself and it works fine. I moved the left hand mirror (just the mirror itself with the light and heated part) to the right and it lights up there.
I then tested resistance on the 2 wires that go back into the car. I get nothing. I then unplugged the entire mirror wiring harness just inside the door and tested from that connection... still no resistance. This tells me there is an issue in the wiring from that point. Problem is I don't know the wiring diagram once those two wires go through the door into the vehicle.
I Think the wires go uninterrupted back to the module but I am not sure. If so that may mean the wire is cut or shorted in between.
