Andredqg5 Posted June 24, 2016 Report Share Posted June 24, 2016 Hi, I have a 2008 ford edge limited. I started having a problem with the a/c not blowing cold air at first. It would only get cold when driving. Please help me to figure out the problem Thank you in advance for any help you can provide. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 24, 2016 Report Share Posted June 24, 2016 Does your radiator fans come on when switch on the ac? May not be getting sufficient airflow through the condenser if the fans aren't working at idle but get airflow when moving (esp above 30 mph). Other thoughts are low refrigerant. Pressure builds with engine speed. (Do you get cold air at idle if you goose the engine, say 3000 rpm)? Getting any codes? If you don't have a code reader, usually can get you codes read at Auto Zone or simular place. 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 24, 2016 Report Share Posted June 24, 2016 Also make sure coolant is at FULL COLD level in degas bottle when engine has cooled off. Quote Link to comment Share on other sites More sharing options...
