RNmom0226 Posted June 19, 2016 Report Share Posted June 19, 2016 Just today I have noticed this very random very subtle (but enough to get on your nerves) beeping. There is no pattern to the beeping. It will even beep before you put the key in the ignition. The beeping sounds like an old phone dialing, that is the closest thing I can compare it to. It is DRIVING me insane! Can someone PLEASE help me out?!? Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 20, 2016 Report Share Posted June 20, 2016 Did you buy the car used? Might be some aftermarket alarm. If not, maybe a video/sound clip will help others understand what it is. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 20, 2016 Report Share Posted June 20, 2016 (edited) Throw out some thoughts. All your doors shut tight, including the rear hatch? (Try manually opening shutting all). Does the airbag light illuminate when you start the car? (Bad buld/circuit has a beep warning that's intermittent). Either 5x5 or 3x2 dings. Is the airbag light lit after running? (Used car, no airbag, bad ground, burnout buld). Try fastening the passenger seatbelt. If it stops, try unplugging and the replugging the connecters under the front seats. As it's a pattern, soulds like an error code (simular to that of a personal computer when it couldn't display the problem on the screen it will issue beeps). Try to catch the pattern, such as 3 beeps, them 2 beeps, short silence then it repeats. Airbag is 5 chimes for 5 times, the silence. Repeats after several minutes. Ford has a beep warning built in to indicate a problem it has detected, if it can't inform you otherwise. Catch the pattern and Google it such as "Ford beep 3+2". Kind of sounds like the airbag light is bad, except it shouldn't be doing this with the key out. Only alarm I can think of when the car is off is the headlight alarm. One additional thought. How old is your battery? Edited June 20, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
Shawn Campbell Posted August 5, 2016 Report Share Posted August 5, 2016 Throw out some thoughts. All your doors shut tight, including the rear hatch? (Try manually opening shutting all). Does the airbag light illuminate when you start the car? (Bad buld/circuit has a beep warning that's intermittent). Either 5x5 or 3x2 dings. Is the airbag light lit after running? (Used car, no airbag, bad ground, burnout buld). Try fastening the passenger seatbelt. If it stops, try unplugging and the replugging the connecters under the front seats. As it's a pattern, soulds like an error code (simular to that of a personal computer when it couldn't display the problem on the screen it will issue beeps). Try to catch the pattern, such as 3 beeps, them 2 beeps, short silence then it repeats. Airbag is 5 chimes for 5 times, the silence. Repeats after several minutes. Ford has a beep warning built in to indicate a problem it has detected, if it can't inform you otherwise. Catch the pattern and Google it such as "Ford beep 3+2". Kind of sounds like the airbag light is bad, except it shouldn't be doing this with the key out. Only alarm I can think of when the car is off is the headlight alarm. One additional thought. How old is your battery? I am having this problem with the beeping and I found a post saying that it could be the airbag light. I checked and sure enough, my airbag light does not come on when I turn the key. Every other light in the instrument cluster lights up, except for the airbag light. Having it narrowed it down to that, how do I fix this issue? Is it a situation where I can remove the instrument panel and replace a bulb/LED or re-solder the board? Do I have to buy a whole new instrument panel? Please help, my wife is going crazy with the beeping! Quote Link to comment Share on other sites More sharing options...
Shawn Campbell Posted August 9, 2016 Report Share Posted August 9, 2016 I'm pretty sure it is an LED that is burnt out, which is not as easy to replace as I believe it is part of the circuit board for the whole instrument cluster. I found the whole cluster online for about $500, but does anyone have any experience or idea how to fix this without replacing the whole cluster? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 9, 2016 Report Share Posted August 9, 2016 It would probably be a lot cheaper to just have it repaired. Here's an example of one shop that does it for around $150: https://circuitboardmedics.com/ford-instrument-cluster-repair/?sort=featured&page=1 Google ford instrument panel repair. You might get lucky and find someone local that performs this service. Consider talking to your local service manager and see if he knows of any lcoal service that he would recommend. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 10, 2016 Report Share Posted August 10, 2016 If the Airbag light is not coming on, I'd suggest checking for trouble codes before attempting a fix. Quote Link to comment Share on other sites More sharing options...
Shawn Campbell Posted August 10, 2016 Report Share Posted August 10, 2016 It would probably be a lot cheaper to just have it repaired. Here's an example of one shop that does it for around $150: https://circuitboardmedics.com/ford-instrument-cluster-repair/?sort=featured&page=1 Google ford instrument panel repair. You might get lucky and find someone local that performs this service. Consider talking to your local service manager and see if he knows of any lcoal service that he would recommend. Thanks for the recommendation, they said they don't do anything with the myford touch clusters, but I really do think it will be an easy fix if i can just find the LED to replace it with. Looks like just a tiny bit of soldering from these pics I found from the fusion forum: http://www.fordfusionforum.com/topic/7158-custom-gauge-cluster/ Anyone know where I can buy something like this? I'm pretty sure it should be amber in color. Quote Link to comment Share on other sites More sharing options...
Shawn Campbell Posted August 10, 2016 Report Share Posted August 10, 2016 If the Airbag light is not coming on, I'd suggest checking for trouble codes before attempting a fix. Makes sense, I've read a lot of people saying it burns out due to being on all the time because of a trouble code. Sorry if this is a stupid question, but I've only dealt with check engine codes. Would airbag codes come up the same way as a DTC on an OBDII scanner? I would just go out and check, but my wife and I often work opposite shifts, so I am just trying to plan to do this next weekend and want to make sure I have everything ready to go. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 10, 2016 Report Share Posted August 10, 2016 I don't know if all scanners can show it, but some do. Quote Link to comment Share on other sites More sharing options...
droberts1983 Posted August 13, 2016 Report Share Posted August 13, 2016 2016 Edge In the last couple weeks I've had a two-tone (or high-low) beeping at 1/2 second intervals. It may be just one pair of beeps, or it may go on for up to 10 pairs. It happens randomly, but this past Thursday I probably had it happen 10 times in the span of a couple hours of driving. As first I thought it was my Garmin GPS, but after unplugging it and turning it off, the beeping continued at random times. There are no idiot lights or entertainment display alerts associated with the beeping. I called Ford and the service department representative had no idea. This is a 2-month old 2016 Edge. Some Google searching could potentially point toward something between Sync and my iPhone, but nothing on-line gives me concrete direction. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Guest JMC Posted March 9, 2020 Report Share Posted March 9, 2020 I had the same issue with the random annoying beeps. Using the sync I turned off auto update. Then I turned auto update on and waited, it did not find any updates but the beeping stopped. I hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest Edgeowner Posted March 12, 2021 Report Share Posted March 12, 2021 My edge beeps while off. Just sitting in the driveway. Sounds like it's coming from under the hood. Quote Link to comment Share on other sites More sharing options...
