Engine coolant question
satryn
Hey all
Just bought a 2013 Ford Edge Sel!
I was checking the oil to see how clean it was when i noticed the engine coolant was pretty low and the cap was loose. Its about an inch or 2 lower than the minimum level mark.
Im a newb when it comes to this stuff and am wondering if 2 inches below the fill line could have damaged the engine in anyway.
Im going to top it up asap
Distilled water only please, you can find at any grocery store. No tap or sparkling or ... water :)
You can also use a "universal" coolant to top off, such as 50/50 Prestone or Zerex brands. Should meet or exceed Ford specification WSS-M97B44-D2 / ASTM D 3306
For example:
PRESTONE
https://www.amazon.com/Prestone-AF2100-Extended-Life-Antifreeze/dp/B000GKTYNI/
Meets or exceeds ASTM D-3306, ASTM D-4985
ZEREX
https://www.amazon.com/Zerex-ZXG05RU1-G-05-Antifreeze-Coolant/dp/B0033QQ4VW/
Meets or exceeds ASTM D3306, ASTM D6210
It does kinda look pinkish from pics I have seen on the net, nothing to worry about. But safest is definitely either distilled water OR Motorcraft coolant (prediluted if you dont want to worry). To save money get the Motorcraft concentrated coolant, mix 1/2 the amount you need 50/50 with distilled water, and pour it in.
Edited by WWWPerfA_ZN0W
