t0lkman Posted June 15, 2016 Report Share Posted June 15, 2016 Hi there my car is "Ford edge 2016 Titanium - White Platinum (UG)", I've noticed a small chip on the inner side of the driver door, but I can clearly see the color is different inside the doors it's not White Platinum (UG) for sure, it looks like it much less "pearlish". The driver sticker states "The exterior color code is UG and interior is PC" What is interior color code btw? Also how can I find exact color which Ford used on inner side? Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 15, 2016 Report Share Posted June 15, 2016 Ask your, you know.... dealer? Quote Link to comment Share on other sites More sharing options...
akirby Posted June 15, 2016 Report Share Posted June 15, 2016 The interior code is not paint, it's the color of the dash, seats, carpet, etc. White platinum is a 3 part paint - base, mid-coat and clear. The mid-coat is what gives it the pearlescence appearance and I don't think they apply the mid-coat to the door jambs, etc. - just the base coat. Quote Link to comment Share on other sites More sharing options...
ONEDGE16 Posted June 15, 2016 Report Share Posted June 15, 2016 I would just take it back to the Dealer and ask them to Fix it under the paint warranty. the other option is to get the touch up paint from Ford, though it would not be an exact match for the Door Jambs. Quote Link to comment Share on other sites More sharing options...
akirby Posted June 15, 2016 Report Share Posted June 15, 2016 You can get the base coat touch up paint from paintscratch.com. Should match just fine without the mid-coat. Quote Link to comment Share on other sites More sharing options...
t0lkman Posted June 16, 2016 Author Report Share Posted June 16, 2016 I don't want to bring it to the dealer and be without car for a day. The chip is super tiny, the only reason I care is it can get rusty if I won't fix it. Probably i shouldn't even care about the color, since it's inside the door just any white paint/lacquer should work Quote Link to comment Share on other sites More sharing options...
t0lkman Posted June 16, 2016 Author Report Share Posted June 16, 2016 I've just bought this one https://www.amazon.com/gp/product/B0122B93ZC/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 Quote Link to comment Share on other sites More sharing options...
akirby Posted June 16, 2016 Report Share Posted June 16, 2016 That will work. You probably only need the basecoat pen. Quote Link to comment Share on other sites More sharing options...
27Sport Posted July 10, 2016 Report Share Posted July 10, 2016 I don't want to bring it to the dealer and be without car for a day. The chip is super tiny, the only reason I care is it can get rusty if I won't fix it. Probably i shouldn't even care about the color, since it's inside the door just any white paint/lacquer should work The only way it could rust is if you see the actual metal. If the chip is white will not rust as it's still painted. Quote Link to comment Share on other sites More sharing options...
t0lkman Posted July 11, 2016 Author Report Share Posted July 11, 2016 I saw actual metal ;( Quote Link to comment Share on other sites More sharing options...
