rear climate control and GPS time on display
i was going through the functions on my new 2016 Edge and came across a couple of areas where there is a bit of ambiguity in the owner's manual.
first, when i go to climate control on the sync 3 display, there is no button for the rear seats. is that button only for the seat heating? i was under the impression that it was for the HVAC as well but since i didn't get the rear seat heating and the button is not there i am now assuming that the button is only for the seat heating.
second, when i go to settings/clock there are options for 12/24 hour display and to reset the time using the GPS. when i press the set the time to GPS button, it sets the time but it is two hours off (early). i see a message stating that the system does not take daylight savings into account. there is no button for setting the time zone as indicated in the manual. i don't have navigation but that doesn't immediately seem to be the problem because the time sets to the correct minute, just two hours early. when i'm in our underground parking and press the set to gps time, i get a message stating that "gps data unavailable. please try again later" so i assume that it normally does pick up the signal despite me not having nav. why can't i set the time zone so the clock is right?
