ben senise Posted June 4, 2016 Report Share Posted June 4, 2016 when i was researching the 2016 edge, i came across a color chart that listed the colors of different areas of the interior for each interior color choice. for example, if you order ebony black, then upper and lower dash are black, carpet black, the roof liner is a sand color, etc. i've been trying to find that chart again and i simply can't. i would be very grateful to anyone who could point me in the right direction. my goal is to find the color of the visors so that i can find something to cover the airbag warning decals with. i don't want to remove them with alcohol. i've done that before and have not been satisfied with the results. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 6, 2016 Report Share Posted June 6, 2016 Try pg 13 of the brochure? http://www.ford.com/services/assets/Brochure?make=Ford&model=Edge&year=2016 Quote Link to comment Share on other sites More sharing options...
ben senise Posted June 6, 2016 Author Report Share Posted June 6, 2016 Try pg 13 of the brochure? http://www.ford.com/services/assets/Brochure?make=Ford&model=Edge&year=2016 Thanks but that's for the exterior colors. The chart I saw had a breakdown of many different interior areas like upper dash, lower dash, carpets, roof liner, etc. It gives the names of what color each component is depending on what color interior you get. When you get a cognac color interior, some areas are black and other areas are a light sand color. This chart tells you what is what. Quote Link to comment Share on other sites More sharing options...
ben senise Posted June 7, 2016 Author Report Share Posted June 7, 2016 was beginning to wonder if i had been hallucinating but i found it at last, right here in this forum no less. here (post 23): 2016 Edge Color - Upholstery - Wheel Guide - 17-Feb-2016.pdf 1 Quote Link to comment Share on other sites More sharing options...
