bob_loblaw Posted June 2, 2016 Report Share Posted June 2, 2016 Our A/C doesn't blow on high even though the setting is on high. It comes on 5 minutes later or 25 minutes later. It occurs at least once a week sometimes more and typically after the car has sat out in the heat during the day at work. Other wise it cools perfectly. The dealer can't diagnose it since they can't duplicate. Anyone else seen/heard of this issue? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 2, 2016 Report Share Posted June 2, 2016 Blower or blower resistor going bad. Check the cabin air filter/screen first though. Quote Link to comment Share on other sites More sharing options...
bob_loblaw Posted June 2, 2016 Author Report Share Posted June 2, 2016 Thanks, i'll try the cabin filter. That hasn't been replaced in 2 years almost. 1 Quote Link to comment Share on other sites More sharing options...
callatis Posted May 10, 2018 Report Share Posted May 10, 2018 I always leave my Air on Auto, summer or winter. I just started the A/C and I have the feeling it doesn't blow enough cold air. If I manually increase the fan, I can feel the cold air. While on Auto,iIf I lower the temp from 22C to 18C now I can hear the fan speed increasing and blowing a lot of cold air. Any idea? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
akirby Posted May 10, 2018 Report Share Posted May 10, 2018 Have you changed the cabin air filter? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 10, 2018 Report Share Posted May 10, 2018 I would agree with checking the cabin air filter. If it's ok, I would have the charge checked at the dealership. All systems leak very, very slowly. Some more than others. Could be just a little low. When the dealer changed my radiator fans, they also checked thd a/c charge. It was a little low, they charged and I could feel the difference. It was slight, but noticeable. Quote Link to comment Share on other sites More sharing options...
Sanoa Posted September 8, 2019 Report Share Posted September 8, 2019 On 5/9/2018 at 9:29 PM, akirby said: Have you changed the cabin air filter? Does changing the cabin air filter really make a difference in relation to cold air in the cabin? I just can't see how. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 8, 2019 Report Share Posted September 8, 2019 1 hour ago, Sanoa said: Does changing the cabin air filter really make a difference in relation to cold air in the cabin? I just can't see how. Not directly but lack of airflow can cause the coil to ice up blocking airflow. 1 Quote Link to comment Share on other sites More sharing options...
