Tom Champagne Posted May 29, 2016 Report Share Posted May 29, 2016 My wife's 2007 Edge SEL has almost 80K on the clock and was wondering if I should change hoses and belt(s) at this time. a mechanic friend told me just the belt(s) and flush cooling system. Any thoughts? Should I stay with OEM parts? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Brian K Posted May 29, 2016 Report Share Posted May 29, 2016 I'd consider changing the belt but IMO the hoses should be fine. Check them for cracks and bulging though. Also you should change all the fluids. In addition to the coolant, you should consider: transmission (drain and fill), bleed the brakes, suck out the PS reservoir and refill, rear diff, and very important - the PTU. 1 Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted May 29, 2016 Author Report Share Posted May 29, 2016 Thanks for the reply. I'll look at the hoses and check them out. Quote Link to comment Share on other sites More sharing options...
macbwt Posted May 30, 2016 Report Share Posted May 30, 2016 Trans change definitely. Plugs are also due. Belts both the power steering stretchy belt and serpentine. Brake fluid purged and replaced. Power steering fluid replaced. Coolant if it is 5 years old yes change. If you need videos go to the youtube and facebook pages listed in my signature. Or I have tons of them posted on the forum here. 1 Quote Link to comment Share on other sites More sharing options...
