Side mirrors w/ turn signal
Stoln
I have a 2013 Ford Edge SEL AWD and was wanting to change the side mirrors to the ones with the turn signals. I found some from TASCA Ford Parts, but they come heated and blindspot and memory. I just have heated mirror. Does anyone know if i was to get them and try them would the turn signal and blindspot work since it is the same wires as i would think ford wouldn't change wiring harness just change pins on the mirrors. If anyone could help it would be appreciated.
Blind spot definitely wont work as it also needs sensors at the rear for detection.
As for the signal lights, I don't believe anyone tried it before, best way to check is disconnect the mirror wiring in your Edge & see how many wires are used & if there are any unused connectors on the vehicle side. If all wires/connectors are used, then you'll need to run your own wires for them.
