mjonis Posted May 18, 2016 Report Share Posted May 18, 2016 I noticed that the Edge (and a few others I've looked at) have the parking/emergency brake on the console area where it appears it's fairly easy to accidentally press. 1) Is this parking brake the same as an emergency brake? 2) If so, then what happens if you're moseying along (say, 60-75 mph) and someone accidentally hits/presses the parking brake? Quote Link to comment Share on other sites More sharing options...
akirby Posted May 18, 2016 Report Share Posted May 18, 2016 1 - yes 2 - you have to pull up on it to engage it and you have to hold it to activate it while moving Accidental engagement is not a problem. Quote Link to comment Share on other sites More sharing options...
mjonis Posted May 20, 2016 Author Report Share Posted May 20, 2016 1 - yes 2 - you have to pull up on it to engage it and you have to hold it to activate it while moving Accidental engagement is not a problem. Ah, OK. So pull up for "official" emergency braking usage. Push in for like when you're parking and whatnot. I only ask because when I was test driving a few vehicles with it, I accidentally pushed it because I was resting my arms on the console. LOL Thanks!!! Quote Link to comment Share on other sites More sharing options...
akirby Posted May 20, 2016 Report Share Posted May 20, 2016 (edited) No - you pull up once to activate the parking brake and push down to de-activate it. It will also deactivate automatically if you hit the gas with the driver's door closed. If you're moving and need to activate it for emergency braking you pull up and hold it. That's the way it works on my 2013 Fusion and 2016 MKX - I presume Edge is the same. Edited May 20, 2016 by akirby Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted May 20, 2016 Report Share Posted May 20, 2016 (edited) And you can't use it in the snow to have fun nor to avoid an accident. Edited May 20, 2016 by DRbillZ Quote Link to comment Share on other sites More sharing options...
akirby Posted May 20, 2016 Report Share Posted May 20, 2016 And you can't use it...... to avoid an accident. Of course you can - you just pull up on it and hold it. Works just like a manual parking brake. Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted May 21, 2016 Report Share Posted May 21, 2016 But you can't vary the pressure and the hook up Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted May 21, 2016 Report Share Posted May 21, 2016 But you can't vary the pressure and the hook up and let it off at will Quote Link to comment Share on other sites More sharing options...
akirby Posted May 21, 2016 Report Share Posted May 21, 2016 But you can't vary the pressure and the hook up and let it off at will But you don't really need to do that if you're trying to stop in an emergency. You're correct that it takes away the fun uses, but how often does that get used? Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted May 21, 2016 Report Share Posted May 21, 2016 (edited) Saved my ass once. That's enough. If you live where it snows it's just.... Fun. Cars have taken the fun and skill out of driving. Traction control, abs, electronic brake. A blithering idiot can drive in the snow... and said idiot is still afraid to drive in the snow Now instead of driving and having fun, it's... let's put crap on our car(HIDs, and LEDs) it doesn't need. Edited May 21, 2016 by akirby Language Quote Link to comment Share on other sites More sharing options...
akirby Posted May 21, 2016 Report Share Posted May 21, 2016 Look - if you don't like something just say that and stop denigrating other owners who don't share your opinion on these things. No need for name calling. Their personal preferences are just as valid as yours. 1 Quote Link to comment Share on other sites More sharing options...
JSLovell69 Posted January 1, 2017 Report Share Posted January 1, 2017 I have a 2016 Edge AWD with 500 miles on it. As I was driving today, the electronic park brake warning light came on and I got a message on display that park brake was not functioning as it should and needed to be serviced. Anyone had similar issues? Quote Link to comment Share on other sites More sharing options...
2015 Edge Titanium Posted January 16, 2017 Report Share Posted January 16, 2017 Same has been happening on my 2015 Edge for the past couple of weeks. Supposedly something to do with ABS module or sensor. Dealer has replaced everything Ford has suggested to fix it but it keeps happening. Going back in today for another try. Quote Link to comment Share on other sites More sharing options...
Brenda Hunt Posted August 18, 2024 Report Share Posted August 18, 2024 im in wyoming where apparently it takes at least a year to get parking brake either motor or sensor, but anyway is there anyway i can disable the bell that dings constantly. ive put up with this for over 9 months. 1 Quote Link to comment Share on other sites More sharing options...
