Buying a 2011 EDGE Sport
bligui
Call Sirius radio and ask them to do a radio ID check easiest way to tell if the head unit failed and was replaced with a new one. If it has not been replaced then that is a 1000.00 dollar tab unless it is still able to be covered by ford with the extended warranty they put on those units due to failures. You should get about 23 highway 16 or so in the city if you drive decent.
