Is there a vent tube for the A/C evaporator box 14' Edge?
If similar to 2007-10, should be on driver side of console, pull back carpeting to reveal. Here's a post related to that:
http://www.fordedgeforum.com/topic/8307-hissing-noise-when-ac-is-on-and-im-turning-left/?do=findComment&comment=151698
Any particular issue that prompted this question? If you run the AC for a while and it does not afterwards drip water onto the ground underneath the vehicle (most visible while stationary), that is a situation that likely needs correcting.
I posted a pix from the service manual, in a previous thread. The drain in located at item #4.
http://www.fordedgeforum.com/topic/17975-ac-makes-noise-and-limited-air-flow-when-turning-left/?fromsearch=1
If you crawl under the car, it's just an open tube that sticks down a couple on inches. A blast of air should open it, but I would follow up with a can of Lubegard to kill any mold.
http://api.viglink.com/api/click?format=go&jsonp=vglnk_146324934006617&key=4f95868279975442d20c58420425bb75&libId=io7gtuu90100b4bt000MAddjj46s4&loc=http%3A%2F%2Fwww.fordedgeforum.com%2Ftopic%2F8307-hissing-noise-when-ac-is-on-and-im-turning-left%2F%3Ffromsearch%3D1&v=1&out=http%3A%2F%2Fwww.amazon.com%2Fgp%2Faw%2Fd%2FB0007PHD0S%2Fref%3Dmp_s_a_1_1%3Fqid%3D1463008208%26sr%3D8-1%26pi%3DAC_SX236_SY340_FMwebp_QL65%26keywords%3DLubegard%2Bheater%2Bcore&ref=http%3A%2F%2Fwww.fordedgeforum.com%2Findex.php%3Fapp%3Dcore%26module%3Dsearch%26do%3Dsearch%26andor_type%3D%26sid%3Dee10eafc5081707828f3cb5ad5dc99f8%26search_app_filters%5Bforums%5D%5BsortKey%5D%3Ddate%26search_app_filters%5Bforums%5D%5BsortKey%5D%3Ddate%26search_app_filters%5Bforums%5D%5BsortDir%5D%3D0%26search_term%3DAc%2Bdrain%26search_app%3Dforums%26st%3D0&title=Hissing%20noise%20when%20AC%20is%20on%20and%20I%27m%20turning%20left%3F%20-%202008%20Edge%20%26%20MKX%20-%20Ford%20Edge%20Forum&txt=http%3A%2F%2Fwww.amazon.co...ard%20heater%20core&loAsUuid=io7gtvdt-f47067c4-016f-4538-ba53-0cbdcf8c2caa&rewrit=false
Here's a Youtube video on how to do this
http://api.viglink.com/api/click?format=go&jsonp=vglnk_146324903428514&key=4f95868279975442d20c58420425bb75&libId=io7gmb8w0100b4bt000MAddjj46s4&loc=http%3A%2F%2Fwww.fordedgeforum.com%2Ftopic%2F8307-hissing-noise-when-ac-is-on-and-im-turning-left%2F%3Ffromsearch%3D1&v=1&out=https%3A%2F%2Fm.youtube.com%2Fwatch%3Fv%3DBi22mdXj3wM&ref=http%3A%2F%2Fwww.fordedgeforum.com%2Findex.php%3Fapp%3Dcore%26module%3Dsearch%26do%3Dsearch%26andor_type%3D%26sid%3Dee10eafc5081707828f3cb5ad5dc99f8%26search_app_filters%5Bforums%5D%5BsortKey%5D%3Ddate%26search_app_filters%5Bforums%5D%5BsortKey%5D%3Ddate%26search_app_filters%5Bforums%5D%5BsortDir%5D%3D0%26search_term%3DAc%2Bdrain%26search_app%3Dforums%26st%3D0&title=Hissing%20noise%20when%20AC%20is%20on%20and%20I%27m%20turning%20left%3F%20-%202008%20Edge%20%26%20MKX%20-%20Ford%20Edge%20Forum&txt=https%3A%2F%2Fm.youtube.co...h%3Fv%3DBi22mdXj3wM
Edited by enigma-2
Great, thanks I will look for it this weekend as I'm changing the oil.
I was a having a stale air smell when I turned on the heater. I have not had a chance to use the A/C yet so didn't check for water dripping, but it's getting warm here now.
I suspect I will find the drain hose is not plugged, so it sounds like service with the Lubegard Kool-It is worth a try.
