Forcehammer Posted May 12, 2016 Report Share Posted May 12, 2016 I found a used set of Fusion Titanium 18" alloy wheels that I would like to use with winter tires. Does anybody know the if the hub centre bore and wheel offset of the 2013+ Ford Fusion Titanium 18" alloys is the same as the 18" standard wheels on the 2016 Edge? Assuming the 18" Fusion Titanium wheels will have enough clearance for the front brake calipers of the Edge. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 12, 2016 Report Share Posted May 12, 2016 not off hand but considering they run same chassis and share A LOT of parts, should be easy to find out. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 13, 2016 Report Share Posted May 13, 2016 (edited) You can do a search on tirerack.Com and check to difference between the two cars for the OEM 18" wheels. 2013 Fusion Titanium Size: 18x8 Offset: 48mm Backspacing: 7.204 Bolt pattern: 5-108 Rec tire size: 235/45-18 2016 Edge Sport Size: 18x8 Offset: 48mm Backspacing; 6.377 Bolt pattern: 5-108 Rec tire size: 245/60-18 Edited May 13, 2016 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
