TourGuide Posted May 7, 2016 Report Share Posted May 7, 2016 Does this lighting come on only at dusk? I had a 15 Escape with the led accent lighting and it was on all the time - headlights on or not. Quote Link to comment Share on other sites More sharing options...
pnewby Posted May 7, 2016 Report Share Posted May 7, 2016 Still waiting for my Sport to arrive this week, but I wonder if yours has the configurable DRL feature that allows them to be turned on or off? I think Titanium and Sport models have this. Check the owners manual for instructions to turn them on and off. Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted May 7, 2016 Report Share Posted May 7, 2016 Does this lighting come on only at dusk? I had a 15 Escape with the led accent lighting and it was on all the time - headlights on or not. the signature lights on the bumper are on 24/7 The DRL is located in the headlight housings and with some packages can be turned off. I have never used my DRL bulb. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted May 8, 2016 Author Report Share Posted May 8, 2016 the signature lights on the bumper are on 24/7 The DRL is located in the headlight housings and with some packages can be turned off. I have never used my DRL bulb. Thanks for the reply. That was what I suspected. I'm going to have to try turning the daylight running lights off and see if I can get the accent lights to come on. If that doesn't work then my car has a set that isn't working. Interesting side note - 'signature lamp' is mentioned exactly 2 times in the manual - both in the maintenance section. The first time it appears is a mention on how you can't service it yourself, and the second time is a mention on what type of bulb is used in those lights. Quote Link to comment Share on other sites More sharing options...
EDGEZEKE Posted July 2, 2017 Report Share Posted July 2, 2017 Can't believe Ford gave us signature lamps instead of actual led daytime running lamps on the Edge. They are worse than useless. Quote Link to comment Share on other sites More sharing options...
