Filtercharged07 Posted May 2, 2016 Report Share Posted May 2, 2016 07 Edge 3.5L AWD 127k miles When I have the Edge parked on an incline and shift out of park, the load dissipates and a loud "clunk" is heard as usual when reverse engages. However, this clunk continues to reverberate sometimes until i move off of the incline. It's almost like a tinny rattling sound, like something is bouncing around the front end of the vehicle once the transmission is in gear. The transmission also makes a strange sound in reverse, like a very quiet ticking when backing up an incline. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted May 2, 2016 Report Share Posted May 2, 2016 Maybe the parking pawl is acting up? I know that when I park the Edge on an incline (backed into the spot), I shift into gear first before releasing the parking/emergency brake OR the brake pedal. Then I have no or minimal clunking/harsh shifting into gear. Quote Link to comment Share on other sites More sharing options...
IWRBB Posted May 2, 2016 Report Share Posted May 2, 2016 (edited) As mentioned above, you really should learn to use the parking brake to take the strain off the parking pawl. I've been parking cars on steep driveways for half of my life so I just do it without even thinking about it now. 1) Stop where you want to park. 2) Hold your foot on the brake pedal. 3) Push the parking brake pedal down as far as you reasonably can. 4) Put it in park. 5) Let go of the regular foot brake. When you leave: 1) Foot on brake to start it. 2) Put it in D or R. 3) Release the parking brake. 4) release foot brake and drive away. The goal is to have the parking brake hold majority of the vehicle's weight, not the parking pawl. Edited May 2, 2016 by IWRBB 1 Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted May 2, 2016 Report Share Posted May 2, 2016 I know when you park on an incline WITHOUT the E brake, the car is basically resting on the parking pawl so shifting out of P will give you a clunk. This is why when I park on an incline, I always engage the E brake FULLY before shifting into park. I have had an issue in the past where there as some extra vibration from the front end when reversing with moderate throttle and reversing uphill. This was due to a worn engine mount. 1 Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted May 2, 2016 Report Share Posted May 2, 2016 (edited) As mentioned above, you really should learn to use the parking brake to take the strain off the parking pawl. I've been parking cars on steep driveways for half of my life so I just do it without even thinking about it now. 1) Stop where you want to park. 2) Hold your foot on the brake pedal. 3) Push the parking brake pedal down as far as you reasonably can. 4) Put it in park. 5) Let go of the regular foot brake. When you leave: 1) Foot on brake to start it. 2) Put it in D or R. 3) Release the parking brake. 4) release foot brake and drive away. The goal is to have the parking brake hold majority of the vehicle's weight, not the parking pawl. I *always* use the brake JUST enough to keep the car from resting on the parking pawl. Edited May 2, 2016 by mcali6301 Quote Link to comment Share on other sites More sharing options...
