Roadmaster Tow Bracket for 2007 - 2015 Edge
i20sailor
XL Series 'Hidden' Brackets
The visible portion of the brackets, the "front arms," can be easily removed when not towing -- remove two hitch pins to convert from towed car to road car in seconds!
They're virtually invisible -- improved aesthetics
Computer-cut, all-steel components for exceptional strength
Easy to install -- ROADMASTER brackets use existing attachment points on the vehicle's undercarriage -- no welding!
Most install through the grille -- no scraping brackets in dips or against curbs.
The bracket will fit 2007 - 2015 Ford Edge without Adaptive Cruise Control
It was installed for 2 years and is in very good condition. All installation hardware included.
Grill piece for 2011- 2014 Edge with correct cut-outs also included.
Conatct Claus Schnabel at claus.schnabel@us.bosch.com
